Unclear situation involving roots.
  • Thread starter Thread starter QED-Kasper
    Roots
The discussion centers on the mathematical interpretation of rewriting equations involving roots and the implications of using the ± sign. One participant argues that the book's solution, which only provides the positive root, is incomplete because it does not account for the negative root, while others clarify that the notation used in the book denotes the principal value, which is conventionally the positive root. The conversation also explores whether a function can have multiple values, concluding that a function must be single-valued, thus justifying the book's approach. Furthermore, the distinction between expressions like a^(1/2) and √a is emphasized, with the former allowing for both positive and negative solutions, while the latter is strictly the principal value. Ultimately, the consensus is that the book's answer is valid within the context of defining A as a function of r.
QED-Kasper
Let's say we have:
A=B3
r=6B2
and we want to rewrite A in terms of r.
My way to do it is:
B2=r/6 => B=+-\sqrt{(r/6)} => B3=+-(r/6)\sqrt{(r/6)} => A=+-(r/6)\sqrt{(r/6)}
In a book I found the following solution:
B2=r/6 => B3=(r/6)1.5 => A=(r/6)1.5
As you can see the book doesn't put a +-. Doesn't this mean that their answer is wrong as it only gives the positive answer? I think this can be brought back to a simpler problem:
\sqrt{4} = 2
not +-2.
+-\sqrt{4} = +-2Writing the 4 within the root symbol doesn't by definition imply that its either +-2, right?. It means that this is a positive root of 4. In order to include both the positive and negative root of 4 one must write +- in front of it, right? So does this mean that the books answer only includes the positive value, thus making it an incomplete and wrong answer?
I would like to add that in the book itself, the problem is stated as follows: Rewrite this system of equations as A(r) = and rearrange (its from a dutch book, I'm not sure if rearrange is the proper word in English) as far as possible.
So if A is a function of r, it means that it can't have both + or - values for the same r. So is the books answer valid in that case as only the principal value is taken to be a valid solution of the function? Or is it still wrong as the ± sign has to be used, because it symbolizes there are two functions and the answer actually includes two separate functions. Or maybe then the ± sign has to be put in front of the A aswell? (to distinguish between two functions, because A(r) by definition only defines one function so either another F(r) has to be put there for the negative equation, or one can just write ±A(r) where -A(r) = F(r))
Thank you.
Mathematics news on Phys.org
Hi QED-Kasper! :smile:
(have a square-root: √ and a ± :wink:)
Yes, I agree with you …
for example, if A = B = -1 and r = 6, then A = minus (6/6)1.5 :smile:
hi tiny-tim :)
Thank you! So (r/6)1.5 doesn't by definition include both the positive and negative value? I have a friend who claims otherwise. He said that he wouldn't put a +- sign unless he would calculate out this expression for example if he had a value for r. (He also claims that \sqrt{4} inherently means -2 or +2.) He says that just raising both sides of the equation to the power of 1.5 is enough and that no +- has to be written in front.
I somehow struggled to explain why I thought this is wrong. Could you elaborate a bit further on this, so I could logically and mathematically be able to explain to my friend why this is wrong?
(what happened to that √ i gave you? :confused:)
Certanly not.
Any expression like that, or √, or sin-1 etc, is deemed to give the principal value.
The principal value is established by convention … in this case, as the positive value.
(btw, try asking your friend whether he would say that (r/6)1.49 and (r/6)1.51 also include a negative value :wink:)
hi again :D
√ ± i like these signs, thanks :) how do you make them?
OK, to be a bit more extreme, is there any "law book" that I could use as a proof, that the "principal value" rule (when writing just √4 it means its equal to 2) , has indeed been established?
"(btw, try asking your friend whether he would say that (r/6)1.49 and (r/6)1.51 also include a negative value ) " I'm sorry, could you explain what you mean?
I make them by just typing on my standard Mac keyboard (they've been standard every since Macs started). :wink:
If you don't have a Mac, you will have to copy them from my post above. :biggrin:
Not that I know of.
It's just a bit obvious that every function is supposed to have a unique meaning (ie, be single-valued).
If eg √ could be ±, it wouldn't be a function.
Well, I expect he'd say no to that …
in which case why does he have a special rule for 1.5 which he doesn't have for 1.49 and 1.51? :wink:
I would like to add that in the book itself, the problem is stated as follows: Rewrite this set of equations as A(r) = and rearrange …
That seems to be begging the question, ie it's assuming, for no apparent reason, that A is a function of r. :frown:
(and of course a function must be single-valued)
No. The book is correct.
There is a big difference between a^{1/2} and \sqrt a. The first denotes both the positive and negative solutions. The latter denotes the principal value only. In general, a^b is a multi-valued function.
Sometimes a textbook will state that all values are nonnegative for a set of problems involving exponents, in order to avoid this confusion. I wonder if that could be the case here.
@D H
tiny-tim said:
Certanly not.
So tiny-tim is wrong?
From http://mathworld.wolfram.com/SquareRoot.html
Any nonnegative real number x has a unique nonnegative square root r; this is called the principal square root and is
written r=x1/2 or r=√x.
There appears to be no difference in meaning between both notations according to wolfram. :s
How many values then would 2^\pi represent? And could you define 2^\pi as the limit of 2^q as q approaches \pi through rational values? If not, how would you define it and would the same definition apply to 2^{1/2} ?
And would you say the derivative of 2^x is undefined in \mathbb{R}^+?
I have a problem with this. You have to be very careful with your notation. Normally when we write "x= \pm a" we mean that either of those two values will satisfy whatever properties x is supposed to satisfy.
That is not the case here. If B= 1, then r= 6 and so \pm\frac{r}{6}\sqrt{\frac{r}{6}}= \pm 1.
But, in fact, A= B3= 1 only.
If B= -1, on the other hand, r= 6 still and \pm\frac{r}{6}\sqrt{\frac{r}{6}}= \pm 1 but now A= -1 only.
With A= B^3 and r= 6B^2 we simply cannot "write A in terms of r only". Calculating r loses information about B (its sign) that is essential for calculating A.
We can only say that if A= B^3 and r= 6B^2 then A is either \frac{r}{6}\sqrt{\frac{r}{6}} or -\frac{r}{6}\sqrt{\frac{r}{6}} but we don't know which.
Both answers are valid because both satisfy all equations so the ± is justified. The reason why I must use the ± sign is exactly because we don't know the value of B, it could be negative or positive. But we do know the value of r, which is positive. I'm not sure what you mean though. I'm just confused why the book doesn't have a ± in front of its answer. Doesn't the answer unjustly only include the positive value?
I still think I'm right.
If a1/2 a3/2 etc are double-valued, then presumably z1/6 is 6-valued, and so is z3/6
so z3/6 ≠ z1/2.
I do accept there could be a convention that makes that last equation true, but I've never come across it.
(and while I'm not unhappy about such a convention for z9/6 and z3/2, I woulnd't like it for exponents written non-fractionally, as in z1.5)
However, even if that convention applies, it doesn't make the book correct …
the statement A = (r/6)1.5 would give A two values, while in any particular case it clearly only has one value.
HallsofIvy :smile: makes a similar point about ± …
But, in fact, A= B3= 1 only …
… A = ±(r/6)1.5 is just as wrong as A = (r/6)1.5 would be under the two-valued convention, and for the same reason.
The first supposition is correct; the latter is not. z3/6 is double valued. Think about it in terms of the primitive roots of unity.
oops!
oops! :redface:
so z3/6 ≠ z1/2.
I believe when defining rational powers the convention is rather to make the last (in)equation false. I quote from Wikipaedia:
________________________________________________________________________
When one speaks of the n-th root of a positive real number a, one usually means the principal n-th root.
Rational powers
A power of a positive real number a with a rational exponent m/n in lowest terms satisfies
a^{m/n}=(a^m)^{1/n}=\sqrt[n]{a^m}
where m is an integer and n is a positive integer.
Note the reference to lowest terms.
But since this definition would generally be restricted to the positive reals, and the definition z^w=e^{wLog(z)} (with Log meaning the principal log) used when complex numbers are involved, there would only be two values to consider for x^{1/6} in this case, even for people who wish to take x^y to be multivalued.
It is clear that Wikipaedia at any rate agrees with you that the definition of x^y is normally taken to be single valued.
The questions I posed in my previous post were intended to suggest that any multivalued definition (if that could properly be called a definition) would be unworkable.
Wikipedia is not the best source for resolving a dispute. You must admit that there certainly is some utility to having a multifunction that represents both solutions of x2-a=0 , and also quite a bit of utility to having a function that represents the principal value.
In any case, we have wandered a bit from the original post. As Halls pointed out, there is only one solution, not two. Using ± is incorrect. A will be positive if B is positive; there is no negative solution. Similarly, will be negative if B is negative; there is no positive solution in this case. If the problem specified that B is positive (we don't know) then the book's solution correct assuming the book is using (r/6)1.5 to denote the principal value.
I have to admit to failing to understand the distinction. I would count two solutions.
If a circle of radius 2 be drawn with centre (0,1) I would be quite happy to say that it intersects the x-axis when x = ±√3.
It will only intersect the x-axis at -√3 when the angle \theta between the radius and the positive direction of the x-axis is \pi/6 and it will only intersect the x-axis at +√3 when \theta is 5\pi/6. But I don't see how the value of \theta is relevant to the statement in the previous paragraph.
Similarly for the value of B in the original question.
But I would certainly agree with you that if the book specified that B (or A) were positive the answer it gave would be correct.
All we know is that B squared is equal to some positive value. So B could be negative and positive. Thus the final answer could be negative and positive. So how can the book be correct?
Sorry, I just noticed that you already said in #12 that you weren't given the sign of B, in which case I'd agree with Tiny Tim that the book is incorrect and the expression you originally gave is correct.
But as you can see there would also be dissenting views.
i formulated the problem in my original post.. B's sign isn't given there either. ;p It's confusing what all these people are talking about, about x^(1/6) having six values for example. :s or x^(1/2) and √(x) meaning different things. Especially when it says different in this website: "Any nonnegative real number x has a unique nonnegative square root r; this is called the principal square root and is written r=x^(1/2) or r=√(x)." http://mathworld.wolfram.com/SquareRoot.html
