Understanding Gas Laws: Boyle's, Charles', and the Conceptual 'What If' Question
The discussion centers on the gas laws, specifically Boyle's Law and Charles' Law, and explores a conceptual "what if" scenario regarding the relationships between volume, pressure, and temperature of an ideal gas. The scope includes theoretical understanding and conceptual reasoning.
  • One participant questions the implications of increasing the volume of an ideal gas, noting that while Boyle's Law suggests pressure decreases with increased volume, an increase in volume should also lead to an increase in temperature and pressure, indicating a potential contradiction.
  • Another participant clarifies that the question involves two different conditions, suggesting the use of Charles' Law to relate volume and temperature under varying conditions.
  • A third participant emphasizes that the initial question is valid and explains that Boyle's and Charles' Laws are simplifications that assume constant conditions for other variables, which may lead to confusion when considering multiple changes simultaneously.
  • This participant introduces the ideal gas law and the relationship between energy and temperature for ideal gases as more comprehensive equations that account for changes in multiple variables.
Participants express differing views on the initial question's validity and the implications of the gas laws. There is no consensus on the resolution of the conceptual conflict presented in the "what if" scenario.
The discussion highlights the limitations of applying gas laws without considering the constancy of other variables and the complexity of real gas behavior compared to ideal gas assumptions.
pibomb
This is an absurd question, but the answer is beyond me:
According to Boyle's Law, we get the relationship: P=k/V (k=constant)
According to Charles' Law, we get: V/T=k
And, P/T=k
My question is rather an conceptual "what if": if we increase, say, the volume of the an ideal gas, it's pressure would go down. Yet, an increase in volume should lead to an increase in temperature, and this an increase in pressure. This can't be right, and though I know I'm missing something fundamental, I can't figure out what that is.
The problem is you are considering two different conditions; one at V1 and another at V2.
Charles law for two conditions is V1/T1=V2/T2 and P1/T1=P2/T2.
Hope this helps.
Oh I see, thanks.
This is not an absurd question at all. But here is the problem: Boyle's and Charles' Laws are simplifications of a more complex relationship for ideal gases. To stay simple, each Law needs to assume that all other variables are constant. For example, P=k/V assumes constant temperature, V/T=k assumes constant pressure, and P/T=k assumes constant volume. This is why your thought experiment didn't work.
So if you want to work with changes in multiple variables (which is usually the case in real systems), you need the more general equations
pV=nRT\quad\quad U=cRT
the first of which is the ideal gas law and the second is the relationship between energy and temperature for an ideal gas.
9K
