Understanding Real and Virtual Images: Definition and Doubts Explored
  • Thread starter Thread starter aalver
    Images
Real images occur when light rays converge at a specific location, allowing them to be projected onto a surface, while virtual images appear to originate from a location behind a reflective surface, such as a plane mirror. In the case of two inclined mirrors, rays from a point object can reflect and appear to converge, but this does not constitute a real image unless the rays actually meet in space. The discussion highlights confusion about whether multiple reflections can create a real image and emphasizes that intensity is not a determining factor for image classification. Ultimately, the distinction lies in whether light converges in reality or is merely traced back to an apparent point behind a mirror. Understanding these definitions clarifies the nature of images formed by reflective surfaces.
aalver
What is the exact definition of a real/virtual image?
This is what gave rise to the doubt. Suppose we have a pair of plane mirrors inclined at any angle. A point object lies on the angle bisector of the two mirrors. Now,the object sends out 2 rays,one towards each mirror. These will intersect at a point on the angle bisector after reflection from the mirrors. Is this a real image?
If we follow this, we will find that the whole space is filled with such "images" of the object. But I feel something's wrong here.
If we say that all rays emitted by one point of an object should meet at a single point for the image to be real, do we also imply that the image should have an intensity comparable to the object?
To have a real image, light must actually converge at the location of the image. When you look at your image in a plane mirror, you are looking at a virtual image. Your image is behind the mirror, where no light actually exists.
That's not any kind of image.
To locate the images, imagine that the object sends out rays in all directions (many rays, not just one!). Then find where those reflected rays converge. If the rays actually do converge where the light is (for example, you can project the image onto a piece of paper) you have a real image; if they can be traced back to a point inside the mirror from which they appear to have converged from, you have a virtual image.
Right. That would make no sense.
No. "Rays" are just a way to visualize what's happening. There's no implication that the light will be reflected by the mirror 100%. (It can be pretty close though.)
that makes sense. thanks!
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
