Understanding Spoilers and Down Force: How They Impact High Speed Performance
  • Context: Undergrad
  • Thread starter Thread starter noagname
    Force
The discussion revolves around the role of spoilers and downforce in automotive design, particularly in high-speed performance contexts such as racing. Participants explore how spoilers affect downforce on both the rear and front tires, and the aerodynamic challenges faced by sports cars at high speeds.
  • Some participants question whether spoilers create downforce on the front tires, noting that they primarily affect the rear wheels.
  • There is a suggestion that high-speed cars experience lift at the front due to airflow underneath, raising concerns about stability.
  • One participant asserts that spoilers are used to reduce turbulence at the back of the car, which is a source of drag, but this is contested by others who clarify the distinction between spoilers and wings.
  • Another participant explains that the issue of front lift is addressed by designing cars to be low to the ground and shaping the underside to minimize lift.
  • Discussion includes the use of air dams and splitters in NASCAR and Formula 1 to create downforce at the front, contrasting with the use of spoilers at the rear.
  • It is noted that Formula 1 cars utilize splitters and diffusers to enhance downforce, with a focus on how airflow is managed under the car.
  • One participant mentions the evolution of car design, particularly the shift to high noses in F1, as a means to improve airflow and downforce.
Participants express differing views on the effectiveness and purpose of spoilers versus other aerodynamic features, indicating that multiple competing perspectives remain without a clear consensus.
Some claims rely on specific definitions of aerodynamic components, and there are unresolved questions about the effectiveness of various designs in managing airflow and downforce.
Readers interested in automotive engineering, aerodynamics, and high-performance racing may find the discussion relevant to understanding the complexities of vehicle design and performance dynamics.
noagname
I have looked around online and I can't get a straight answer. I understand that spoiler in the back of a car create down force on the rear wheels. But do they place any down force on the front tires? At high speeds don't cars(sports) have problems with the front end having to much air flow underneath it and the front end being lifted. If so how is that problem solved?
I thought that spoilers were there to reduce (spoil) the turbulence at the back which is a major source of drag. Is that wrong?
You are correct; however "spoiler" and "wing" have become synonymous to the layman.
No.
It isn't solved by spoilers. They are most common for front-engine, rear-wheel drive cars which have enough weight on the front wheels to keep them straight, but need more force on the back wheels to get traction. This problem is generally addressed by making cars that ride very close to the ground to minimize the airflow, and also by shaping the underside of the car body appropriately to not provide lift.
Low to the ground, front wheels for steering only, all the downforce directed to the back wheels by mechanical design and the wing. Designed for extreme speed. Lift is combated by design of the front body.
[PLAIN]http://www.subarupic.com/subaru/car/pictures/2010/04/112-0705-11zpeter-solberg-subaru-impreza-rally-carsliding.jpg
Designed for agility and acceleration: spoiler exists to calm turbulent airflow, all-wheel drive. Liftoff is not an issue as those speeds aren't reached.
Nascar type racing cars use spoilers in the rear for downforce and air dams / splitters up front to block air flow from getting under the car, which ends up reducing pressure under the front end of the car, creating downforce at the front. Formula 1 and other types of race cars use wings and splitters at the front, wings and diffusers at the back. Indy Racing League cars are also allowed to use ground effects (underbody tunneling) for additional downforce (Formula 1 cars have to use a "skid" plate instead).
Wiki article about diffuser and splitter:
http://en.wikipedia.org/wiki/Diffuser_(automotive)
The splitter on an F1 car accelerates air under the floor of the car and provides downforce further back in the car, instead of where the splitter is actually located (in front of the driver).
I believe that the move to high noses from about 1993 onwards is a drive to actually increase airflow under the car in order to improve downforce created by both the splitter and the rear diffuser.
F1 cars also channel exhaust gases into the rear diffuser to create added downforce.
Thank you it all makes sense now
  • · Replies 66 ·
16K
  • · Replies 73 ·
11K
  • · Replies 44 ·
9K
