Understanding the Derivation of Relativistic Mass in Inelastic Collisions
The derivation of relativistic mass in inelastic collisions demonstrates that the relativistic mass is equal to the rest mass multiplied by the Lorentz factor, represented as γ (gamma), which is defined as 1/sqrt(1-u²/c²). The discussion highlights the transformation of velocities in different reference frames, particularly focusing on the vertical and horizontal components of velocity during the collision. Key references include the works of Planck (1906) and Lewis and Tolman (1909), which provide foundational insights into the topic. The transformation equations used are u = u'γ for vertical velocity and u' = (u - v)/(1 - uv/c²) for horizontal velocity.
  • Understanding of relativistic mass and its relation to rest mass
  • Familiarity with Lorentz transformations
  • Knowledge of gamma factor (γ) in special relativity
  • Basic principles of inelastic collisions
  • Study the derivation of the Lorentz transformation equations in detail
  • Explore the implications of relativistic mass in particle physics
  • Read "A History of the Theories of Aether and Electricity, Volume II" by Sir Edmund Whittaker for historical context
  • Investigate the differences between elastic and inelastic collisions in relativistic contexts
Students and educators in physics, particularly those focusing on special relativity, as well as researchers interested in the historical development of relativistic concepts.
mainguy
Hi guys, thanks for helping with this! I'm a little stuck with this question about the derivation for relativistic mass.
1. Homework Statement
By considering the inelastic collision of two balls as perceived in different reference frames show that the relativistic mass is equal to the rest mass multiplied by the gamma factor (sqrt(1-u^2/c^2).
So I know the factor is 1/(1-u2/c2) but proving it is tough.
I've considered a reference frame moving at u in a direction perpendicular to the collision, so basically this:
The vertical velocity u0 is transformed by a gamma factor, u = u'*gamma
So it slows down slightly as expected in the moving frame
It seems to me that the ball moving sidelong, say B in the first image, will have it's velocity altered in two parts. The vertical component will be multiplied by a gamma factor, and the horizontal component will transform as a lorentz:
u'= (u -v)/(1-uv/c2)
It seems clear to me that the vertical velocities of A and B are identical, and that they transform in an identical manner.
From class I know this isn't true, apparently they are identical velocities but they transform in a different manner. But I don't see how B could be transformed via the Lorentz formula if only a compnent of it's velocity is along the line parallel to the motion of the moving frame. Help would be much appreciated![/B]
This is a problem that was treated by Planck in a 1906 paper, but the arguments there are not particularly enlightening. A much nicer and more convincing argument was advanced in a 1909 paper by Lewis and Tolman. You can find this argument nicely laid out more-or-less completely on pages 48--50 of "A History of the Theories of Aether and Electricity, Volume II", by Sir Edmund Whittaker, Harper (1953).
According tot he diagram, frame ##S## is moving to the right at speed ##V##, but according to what you wrote, you have it moving vertically at speed ##u##. You also use ##u## for the speed of one of the particles in the collision.
  • · Replies 71 ·
