Understanding the Formula r=mv/Bq in Grade 12 Physics
The formula r=mv/Bq is derived from the relationship between magnetic force and centripetal force in uniform circular motion. When a charged particle moves perpendicular to a magnetic field, the magnetic force acting on it can be expressed as F=qvB. This force equals the centripetal force required for circular motion, F=ma, leading to the equation qvB=ma. By substituting the expressions for velocity and acceleration, the formula simplifies to r=mv/Bq. Understanding this derivation is crucial for grasping concepts in grade 12 physics.
mayodt
Where did the formula r=mv/Bq come from in my answerbook for my grade 12 physics? Thanks.
Do you know the equation for uniform circular motion, given a force F that always points toward the center of the circular motion?
Do you know the equation for the force F on a charged particle q when it is traveling at velocity v perpendicular to a magnetic field B?
F=qvBsin(theta) is the equation right? and, I probably have seen the first one, but can't remember that specific one.
Correct, but what does it simplify to when the velocity and B-field are orthogonal (at right angles to each other)?
See Uniform Circular Motion at wikipedia, and remember that F=ma:
http://en.wikipedia.org/wiki/Uniform_circular_motion
Ohh okay I got it. Because the force of the magnetic field equals the net force (F=ma) so that means that qvb=ma and then since v=rw and a=vw it's qrwB=mvw, and then the w's cancel out and you rearrange. Thanks a lot :biggrin:
Good job! :biggrin:
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
