Understanding the Impulse Response: A Key Tool for Identifying Unknown Systems
To find the impulse response of a system, substitute the Dirac Delta function δ(t) for the input x(t) in the output function y(t), allowing for the derivation of h(t), the impulse response. This method works because the impulse response characterizes linear time-invariant systems, and the output is the convolution of the impulse response with the input. However, precision can be compromised if the input does not sufficiently excite the system, as seen when using a low-frequency sine wave to analyze a high-frequency response. To accurately identify an unknown system, it is crucial to use an input that adequately stresses the system, such as a step input or frequency sweep. Understanding these principles is essential for effective system analysis and identification.
perplexabot
Hi all. A problem I was working on required that I find the impulse response where I am given the output function ( y(t) ) of a system in terms of the input ( x(t) ). I read somewhere that to find the impulse response, you need a function that relates the output and the input, then you substitute h(t) for every y(t) and δ(t) (the impulse function) for every x(t) then finally solve for h(t) and that would be the impulse response. Assuming what I just stated is correct, my question is why does it work like that? Specifically why does substituting δ(t) for every x(t) lead to the impulse response?
δ(t) is the Dirac Delta function called an impulse. So for a system with impulse as an input the corresponding output would give you the response namely the impulse response.
Impulse response are significant because any linear time invariant system can be characterized by stating just its impulse response.
Hope this answers you query.
The output is the convolution of the impulse response by the input. So if having the input and output, you "could" de-convolve the output by the input to deduce the impulse response.
Though, this is an inverse problem! The equations may look good, but the precision of the result may be extremely bad if the input and output you've observed do not stress the system enough.
Imagine that you're interested in a corner frequency at 1kHz and your input is a sine at 50Hz: you'll observe nothing interesting and deduce a very imprecise corner frequency.
That's why, if identifying an unknown system, we chose an excitation that stresses it properly, for instance a step input or a nearly-impulse input. Or a frequency sweep, equally good.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
