Uneven distribution of charge on a ring problem
The discussion revolves around the challenge of solving a problem related to the uneven distribution of charge on a ring. Participants express confusion and a lack of understanding regarding the solution process. The forum rules prohibit direct solutions, prompting a request for guidance on critical steps instead. Users are encouraged to refer to Section 26-4 for relevant equations and to adapt that example to the current problem. The emphasis is on understanding the underlying principles rather than simply obtaining the answer.
Ahmed Farhan
1.
2. I'm totally lost on this problem. Tried guessing in several ways but couldn't come up with the right answer.3. Since I was totally mesmerized by this problem, I need someone to solve it and provide explanation of critical steps of the process. Can someone help me?
It is against the rules of this forum to provide solutions. Please follow the template and post the relevant equations. Start from the equations given in Section 26-4. Read and understand section 26-4 and see how you can modify that example to what you have here.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
