Calculating Acceleration from Distance and Time: Is This Solution Correct?
To calculate the acceleration of a body that starts from rest and covers 150 m during the 8th second, the formula s = ut + 1/2 at^2 is used. With an initial velocity (u) of 0, the calculated acceleration (a) is 4.68 m/s². The solution is questioned for its correctness, prompting verification through a velocity-time (v-t) diagram, where the area represents displacement and the slope indicates acceleration. The discussion emphasizes the importance of understanding motion equations and graphical analysis in physics. The final calculation and method should be confirmed for accuracy.
abhavi
A body starts from rest along the straight line with uniform acceleration .it covers a distance of 150 m during 8th second of its motion calculate acceralation of body
s= ut+1/2 at^2
u = 0 ;
a = (2*150)/64 = 4.68m/s^2;
Is this right or wrong?please asnwer me as i am posting on behalf of my sister.
That's it.
You can verify it by drawing the v-t diagram... the area is the displacement, the slope is the acceleration.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
