Proving Uniform Continuity of f on [1, $\infty$]
talolard
Hello,
Given that f is continuous in [1,\infty) and lim_{x->\infty}f(x) exists and is finite, prove that f is uniformly continuous in [1,\infty)
We will mark lim_{x->\infty}f(x) = L. So we know that there exists x_{0} such that for every x>x_{0} |L-f(x)|<\epsilon so f is uniformly continuos in (x_{0},\infty)
We shall look at the segment [1,x_{0}+1]. We know that a continuous function ina closed segment is uniformly continuous.
From here I am puzled. I have two routes.
The easy route sais that since we showed f is uniformly continuous in those two segments and they overlap then f is uniformly continuous on the whole segment. I havea feeling this is not enough.
Route 2:
We know that a continuous function ina closed segment has a minimum and maximal value there. Then we can look at the closed segment [1,x_{0}+1] and mark m=MIN(f(x)), M= MAX(f(x)). But since f converges to L from x=,x_{0} we have taken into account all of the possible values of f.
we will mark d= | |M| - |m| | the biggest difference in value f gets.
and from here I am stuck. I am lost as to how to tie up the proof. Gudiance would be greatly apreciated.
Thanks
Tal
I think that I would try to use your "route 1", if you know that the mapping is uniformly continuous in both domains, and they overlap on [x0,x0+1]. Let's call them domains 1 and 2.
Uniform continuity in a domain demands that for any constant epsilon>0, there should be a constant delta>0 such that |f(y)-f(x)| < epsilon for all y with |y-x| < delta.
For a given epsilon, you can find such a delta for domain 1, and one for domain 2, just choose the smallest one of those, and I think is it OK, right? I guess delta also has to be less than the overlap of the two domains. You can always choose such a delta.
It's been a while since I worked on such problems, so please be very critical towards my statements!
Torquil
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
