Uniform Continuity in Bounded Functions and Limits: Examples and Proofs"
In summary, uniform continuity is a property of functions that ensures their slope remains relatively constant and there are no sudden changes or discontinuities over the entire domain. It is a stronger condition than regular continuity and can be proven using the epsilon-delta definition or the theorem stating a function is uniformly continuous if it is bounded and continuous over a closed interval. Uniform continuity is closely related to limits, as it guarantees the existence of a limit at every point in the function's domain and this limit is consistent regardless of the point chosen. This relationship is important in calculus and real analysis.
jdcasey9
28
a) Give an example of a bounded continuous function f: R -> R which is not uniformly continuous.
b) State (in terms of a small Epsilon and a large K) what it means to say that f(x) -> 0 as x -> infinity (plus or minus)
c) Now assume that f: R -> R is continuous and f(x) -> 0 as x -> infinity (plus or minus). Show that f is uniformly continuous.
a) So we need a function that is bounded and continuous, but has an unbounded derivative.
sin(x^2), because 2xsin(x^2) is not bounded. There is not a well-behaved delta for any two values in the domain. No matter how small an epsilon we pick, for x large enough, f(x) will range between -1, 1 for values (x-e, x+e).
b) Since KE = delta, f(x) -> 0 as x -> infinity (+ or -) means that d(f(x) + E, f(x) - E) -> 0 as d(x + delta, x - delta) gets larger.
c) Let E > 0, delta >0. Take x,y contained in R such that d(x,y) < delta. Since d(f(x), f(y)) -> 0 as x-> infinity (+ or -), d(f(x), f(y)) = 0 for large enough x. So we set delta = E and d(f(x) -f(y)) = 0 < delta = E.
Therefore, f is uniformly continuous.
Thank you for posting your question on the forum. I would like to provide a response to your query.
a) One example of a bounded continuous function f: R -> R which is not uniformly continuous is f(x) = 1/x. This function is bounded between 0 and 1, but its derivative is unbounded as x approaches 0.
b) To say that f(x) -> 0 as x -> infinity (plus or minus) means that for any small value of Epsilon, we can find a large value of K such that for all x greater than K, the distance between f(x) and 0 is less than Epsilon. In other words, as x gets larger and larger, the values of f(x) get closer and closer to 0.
c) Now, assuming that f: R -> R is continuous and f(x) -> 0 as x -> infinity (plus or minus), we can prove that f is uniformly continuous. Let E > 0 be given. Since f(x) -> 0 as x -> infinity (plus or minus), we can find a large value of K such that for all x greater than K, the distance between f(x) and 0 is less than E/2. Since f is continuous, there exists a delta > 0 such that for all x, y in R, if d(x,y) < delta, then |f(x) - f(y)| < E/2. Now, let x and y be any two points in R such that d(x,y) < delta. If both x and y are greater than K, then |f(x) - f(y)| < E/2. If one of them, say x, is less than K, then |f(x) - f(y)| < E/2 + |f(x)| < E/2 + E/2 = E. Therefore, for all x, y in R, if d(x,y) < delta, then |f(x) - f(y)| < E, and thus f is uniformly continuous.
I hope this helps to clarify your doubts. If you have any further questions, please do not hesitate to ask.
1. What is uniform continuity?
Uniform continuity is a property of functions that describes how the function behaves over its entire domain. A function is uniformly continuous if for any given value of epsilon (ε), there exists a corresponding value of delta (δ) such that the distance between any two points in the function's domain is less than ε, and the corresponding outputs of those points have a difference less than δ. In simpler terms, this means that the function's slope is relatively constant and does not have any abrupt changes or discontinuities.
2. How is uniform continuity different from regular continuity?
Uniform continuity is a stronger condition than regular continuity. While regular continuity only requires that the function is continuous at every point in its domain, uniform continuity requires that the function's behavior is consistent across the entire domain. This means that there are no sudden changes or spikes in the function's slope, and it remains relatively stable over its entire domain.
3. Can you give an example of a uniformly continuous function?
One example of a uniformly continuous function is f(x) = 2x. This function has a constant slope of 2, and no matter how close together two points are in the domain, the difference in their outputs will always be less than a given delta. Another example is g(x) = sin(x), which has a bounded and continuous slope over its entire domain.
4. How can uniform continuity be proven?
To prove that a function is uniformly continuous, we can use the epsilon-delta definition of uniform continuity. This involves choosing a value of epsilon and finding a corresponding delta value that satisfies the definition. We can also use the theorem that states a function is uniformly continuous if it is bounded and continuous over a closed interval.
5. What is the relationship between uniform continuity and limits?
Uniform continuity is closely related to limits, as it guarantees that the limit of a function exists at every point in its domain. In other words, a uniformly continuous function will have a well-defined limit at every point in its domain, and this limit will be the same regardless of the point chosen. This relationship is important in calculus and real analysis, as it allows us to make more accurate predictions and calculations about the behavior of functions.
