Uniform Electric Field of a proton
In a uniform electric field, a proton experiences constant acceleration in the direction of the field due to its positive charge. The relationship between electric field (E), mass (m), acceleration (a), and charge (q) is given by the equation E = m*a/q. The discussion confirms that the correct answer to the homework question is option c, as the proton's acceleration aligns with the field's direction. The participants agree on the logic that the proton's acceleration and force are directed along the electric field. Understanding these principles is crucial for solving related physics problems.
Soaring Crane
In a uniform electric field, a proton has a
a. constant velocity in the direction of the field.
b. constant velocity in the opposite direction of the electric field.
c. constant acceleration in the direction of the electric field.
d. constant acceleration in a direction opposite the electric field.
e. constant acceleration in a direction perpendicular to the electric
Possibly vector E = m*a/q
Is the correct answer c. constant acceleration in the direction of the electric field?
A uniform electric field has the same magnitude and direction throughout the region. Wouldn't the proton then have a constant acceleration, and the direction of the acceleration (also force?) would be in the field's same direction since the charge is positive?
Thanks.
Correct. Good job.
Your logic seems to be correct.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
