Uniform ladder on a frictionless wall?
To solve the problem of a uniform ladder resting against a frictionless wall, start by drawing a detailed diagram that labels all forces acting on the ladder. Apply the conditions for equilibrium, which include balancing the forces and moments acting on the ladder. Calculate the normal force at the base and the frictional force using the coefficient of static friction provided. This approach will help determine the reactions on both sides of the ladder effectively. Understanding these principles is crucial for accurately solving the problem.
honestliar
An 8.00m uniform ladder whose mass is 55 kg is resting against a frictionless wall. Its lower end is 750cm from the wall. If the coefficient of static friction between the floor and the lower end of the ladder is 0.60, calculate the reactions on both side of the ladder.
Any help please?
What have you done so far?
Start by drawing a diagram of the ladder with every force labeled. Then apply the conditions for equilibrium.
