Uniform rod pivoted off-center
  • Thread starter Thread starter natasha13100
    Rod Uniform
A uniform rod of mass 1.2 kg and length 1.2 m is pivoted off-center and analyzed for its rotational dynamics as it swings downward. The rotational inertia relative to the pivot point is calculated as 0.252 kgm². As the rod swings, its angular speed increases while its angular acceleration decreases. The angular speed when the rod passes the vertical position is approximately 4.43 rad/s, and the linear speed of the bottom end of the rod is derived to be √(3gl/14) m/s, with adjustments made for the distance from the pivot. The discussion emphasizes the importance of using the correct formulas for kinetic energy and the center of mass in rotational motion calculations.
natasha13100
√ω
A uniform rod of mass 1.2 kg and length 1.2 m is pivoted in the horizontal position as shown (black point). The rod is at rest and then released. The acceleration due to gravity is g = 9.8 m/s2.
Part 1. Find the rotational inertia of the rod relative to the axis perpendicular to the screen and passing through the pivot point (in kgm2).
Part 2. As the rod swings downward, its angular speed velocity and the magnitude of its angular acceleration, respectively are (increasing, decreasing, staying the same) and (increasing, decreasing, staying the same).
Part 3. What is the angular speed (in rad/s) of the rod as it passes through the vertical position (when end marked B is at the bottom)?
Part 4. What is the linear speed of the bottom end of the rod (marked B) when it passes the vertical position?(in m/s)
Icm=1/12ml2
Ip=Icm+md2
Ug=mgh
Ui+Ki+Wnoncon=Uf+Kf
Ktrans=1/2mv2
Krot=1/2Iω2
t=Frsinθ
K=Ktrans+Krot
v=ωR
Picture/FBD is attached.
Part 1
Ip=1/12m(l)2+m(l/4)2=1/12*1.2*1.22+1.2*.32=.252
Part 2
increasing and decreasing
Part 3
0=1/2mv2+1/2Iω2+mgh where h=-l/4(distance from pivot to cm which will be directly below pivot when the rod is at the bottom of its swing)
mgh=1/2mv2+1/2Iω2=mgh=1/2mω2R2+1/2Iω2=1/2mω2R2+1/2Iω2
1.2(9.8)(.3)=(1/2(1.2)(.3)2+1/2*.252)ω2=(.18)ω2
ω=√(3.528/.18)=4.42718872424
I am not sure if this is correct, but I used l/4 (distance from pivot to center of mass) as R.
Part 4
mgh=1/2mv2+1/2Iω2
2mgh=mv2+Iv2/R2
2(1.2)(9.8)(.3)=(1.2+.252/.32)v2
v=√(7.056/4)=1.32815661727
or v=ωR2=4.42718872424(.3)^2=0.398446985181
Since these two values for v don't match up, I think I'm doing something wrong.
hi natasha13100! :smile:
i think you're using the wrong formula for kinetic energy
it's 1/2mv2 of the c.o.m. plus 1/2Ic.o.mω2 about the c.o.m. :wink:
(which also equals 1/2Ic.o.rω2 about the instantaneous centre of rotation, ie the pivot)
What does that mean?
So K=1/2mv^2+1/2(1/12ml^2)w^2=1/2mw^2/(l/2)^2+1/24ml^2w^2=w^2(ml^2/8+ml^2/24)
Uf+Kf=Ui+Ki
0=w^2(ml^2/8+ml^2/24)-mgl/4
mgl/4=w^2(ml^2/8+ml^2/24)
g=w^2(l/2+l/6)
w^2=g/(2l/3)
w=sqrt(3g/2l)
and
v=wl/2=sqrt(3g/2l)l/2
or
K=1/2mv^2+1/2(1/12ml^2)w^2=1/2mv^2+1/2(1/12ml^2)v^2/(l/2)^2=v^2(ml/2+1/6m)
gl/4=v^2(l/2+1/6)
v^2(3l+1)/6=gl/4
v^2=3/(6l+2)
v=sqrt(3/(6l+2))
but v is still off
the v in 1/2 mv2 will be (l/4)ω :wink:
(because l24 is the distance from the centre of rotation to the centre of mass)
0=w^2(1/2ml^2/16+ml^2/24)-mgl/4
mgl/4=w^2(ml^2/32+ml^2/24)
g=w^2(l/8+l/6)
w^2=24g/(3l+4l)
w=sqrt(24g/7l) which is correct
and
v=lsqrt(24g/7l)/4 but that's not right.
g=w^2(l/8+l/6)
w^2=24g/(3l+4l)
w=sqrt(24g/7l)
looks ok down to here :smile:
(btw, you'd get the same result if you used the parallel axis theorem, and just 1/2 Ic.o.r.ω2 :wink:)
1/2Ic.o.r.ω2=mgl/4
c.o.r.=Ic.o.m.+m(l/4)2
Ic.o.m.=1/12ml2
1/2(1/12ml2+m(l/4)22=mgl/4
ω2=g/(l(1/6+1/8))=g/l/(7/24)
ω=√(24g/7l)
okay, I see what you mean.
For v, wouldn't you just plug in for ω?
1/2mv2+1/2(1/12ml22=mgl/4
m/2*v2=mgl/4-1/24ml^2*24g/7l=mgl/4-mgl/7
v2=(7gl-4gl)/14=3gl/14
v=√(3gl/14)
yes :smile:
(but in your last post you used the wrong distance … the question asks for v for the bottom of the rod, which is not the same v as you used earlier)
v=√(3gl/14)
i'm confused … what is this? :confused:
Oh that was the v of the center of mass (I think). So for the bottom of the rod, r=3l/4 (distance from pivot to bottom of rod) and v=√(24g/7l)*3l/4
yup! :biggrin:
Likes 1 person
