Units of Flux Density: Electric Field vs Displacement Vector
The discussion centers on the confusion surrounding the term "flux density" in relation to the displacement vector D, defined as D = (e0)E + P. The units of the displacement vector are C/m^2, which raises questions about its relation to electric flux and the electric field, as electric flux density appears to simplify to V/m, equivalent to the electric field. The conversation highlights the complexity of SI units, particularly how C/m^2 resembles surface charge density. Additionally, the application of Gauss's law in differential form clarifies that the divergence of D relates to charge density, reinforcing the unit C/m^2 for D. Overall, the discussion emphasizes the challenges of understanding SI units in the context of electric fields and displacement vectors.
gralla55
While I do understand the use for the displacement vector D = (e0)E + P, I don't quite understand why they label it as "flux density". The units for the displacement vector are C/m^2. The units for electric flux are Vm, so wouldn't electric flux density become Vm/m^2 = V/m which is just equal to the electric field?
edit: C/m^2 just looks like surface charge density...
For this reason, I hate the SI. It's totally unintuitive. Anyway, let's work through the dimensional analysis. According to Gauß's law, which reads in differential form
\vec{\nabla} \cdot \vec{D}=\rho,
where \rho is the charge density (i.e., charge per unit volume), which has the SI unit \mathrm{C}/\mathrm{m}^3 (Coulomb per cubic metre). The Nabla operator is a differential operator wrt. to space coordinates and thus has the unit 1/\mathrm{m}.
This implies that \vec{D} has the unit \mathrm{C}/\mathrm{m}^2.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
