Units of mass- 2.99e+05 tonne
  • Thread starter designerdan08
  • Tags
    Mass Units
In summary, Daniel is a studying designer who is currently using an engineering CAD program to calculate the mass of a part. However, he lacks engineering intellect and is having trouble understanding the results, which are shown in scientific notation as 2.9955623e+05 TONNE. He is seeking help in understanding the notation and unit conversion, as well as questioning the accuracy of the density assigned to the part.
designerdan08
Hi,
Im a studying designer currently working with an engineering CAD program. I have calcualted the mass of the part using an analysis feature in the program. However, I have very little engineering interlect and cannot completely understand the results.
The returned result is 2.9955623e+05 TONNE
If anyone can help me understand this it would be much appreciated.
Cheers
Daniel
Are you asking about the scientific notation or the unit? A 'tonne' usually means a metric ton, which is 1000 kilograms. The number is "computerese" (it goes back to FORTRAN notation) for the value expressed in scientific notation; here, this would be 2.9955623·10^5 or 299,556.23 (which is probably way more significant figures than the number is good for...).
1 tonne = 2204.6226 pounds
It's called a metric ton.
You got the 2.99 x 10^5 part of it I'm guessing.
I appreciate your immediate reply
I thought that may be the conversion but does that mean that it is 299,000 tonnes!? If so the density assigned to the part is incorrect so I must change it
What did you use for the density? Does the input want kilograms per cubic meter or grams per cubic centimeter? (That would make a difference of a factor of 1000.)
What is 2.99e+05 tonne in kilograms?
2.99e+05 tonne is equivalent to 299,000 kilograms.
How many pounds are in 2.99e+05 tonne?
2.99e+05 tonne is approximately equal to 660,000 pounds.
What is the abbreviation for tonne?
The abbreviation for tonne is "t".
What objects or substances are typically measured in tonne?
Tonne is most commonly used to measure large quantities of materials such as steel, coal, or grains.
How does 2.99e+05 tonne compare to other units of mass?
2.99e+05 tonne is equivalent to 2.99e+08 grams, 29,900 metric tons, or 262,500 long tons.
  • STEM Academic Advising
