Unknown mass being pushed up ramp until it hits spring
  • Thread starter Thread starter maxpower612
    Mass Ramp Spring
A block of mass m is pushed up a frictionless incline at a constant speed of 6.00 m/s until it contacts a spring with a spring constant of 200 N/m, at which point the pushing force is removed. The spring compresses by 0.60 meters, bringing the block to rest, and potential energy must be considered due to the incline's angle of 40 degrees. The kinetic energy lost during the block's deceleration is converted into potential energy and spring energy, leading to the equation 1/2mvi^2 = mgHf + 1/2kx^2. After calculating the height using the sine of the incline angle, the mass is determined to be approximately 2.53 kg. The net force on the block when fully compressed is directed down the slope, as it is at rest.
maxpower612
A force F pushes a block of mass m up a frictionless incline as shown below. The block moves
at a constant speed of 6.00 m/s until it contacts the relaxed spring which has a spring constant k =
200 N/m. At the point where the block touches the spring, the force is removed. The spring is then compressed by 0.60 meters until the block comes to rest.
What is the mass of the object in kg?
It is at an angle of 40 degrees. g=9.8 m/s2
The height and length are not given but I'm assuming Hi=0
Also in what direction would the net force be on the block when the block is at rest and fully compressed?
Us=1/2kx2 (1)
Ki+Usi=Kf+Usf (2)
I inserted the values into equation 2 and got 2 kg but I don't think it's right since on an incline, there must be potential energy involved.
Us=1/2kx2 (1)
Ki+Usi=Kf+Usf (2)
The last question is really easy.
In what direction will the mass move?
It it is about to bury itself vertically into the surface, then the net force is down.
If it is about to spring vertically up, then the net force is up.
If it is about to fly off the slope horizontally, then the net force is horizontal.
If it is about to move down the slope, then the net force is down the slope, parallel to the slope.
And if it is going to stay where it is - then the net force is zero.
Us=1/2kx2 (1)
Ki+Usi=Kf+Usf (2)
In red above ... True.
Overview:
When the mass reaches the spring, force F ceases, so we don't have to worry about that.
The mass was moving, so had kinetic energy.
When it finally stops, it will be at a higher elevation - so has gained some PE, and has compressed the spring and stored some energy in there [another gain].
The two gains must total the loss of Kinetic energy as it stops..
I wasn't sure in what direction the net force was since the object was at rest, but the net force moving parallel to the slope seems the most logical answer. Thanks for your reply!
Overview:
So would the equation be 1/2mvi^2+0+0=0+mgHf+1/2kx^2? if so how would I find the final height in order to get the mass?
The height is a component of x.
I took your advice (assuming I did it right) and found the height to be (0.6m)sin40= .386m and plugged into back into the previous equation by getting the mass approximately equal to 2.53 kg. I hope that's right lol
