Proving Upper and Lower Bounds for Continuous Happiness on a Scale of -10 to 10
  • Thread starter Thread starter Numnum
    Bounds
Numnum
Assume happiness can be measured on a scale from -10 (very unhappy) to 10 (extremely happy). Let D denote the set of possible ways to live one day. For each way of living a dayd∈D define a function
h_d:[0,24]⟶[−10,10] to be equal to the value of happiness at each point in time. For example, h_d(6.25)=−7.3 means that for this particular way of living a day the level of happiness at 6:15 in the morning is -7.3 (this may happen if one sets alarm clock to 6:00am). Let H_d=glb {h_d(t)|{0≤t≤24}. Let H=lub{H_d|d∈D}.
1) Assuming that happiness changes continuously, prove that for every d∈D there exists t∈ [0,24], such that h_d (t)= H_d.
2) Assume that happiness changes continuously and that H=4. Is it possible to live through a day so that you are always happier than 3.9999999? Is it possible to live through a day so that you are always happier than 4? Justify your answers.
3) Without assuming that happiness changes continuously, prove that {−10≤H≤10}.
Can you walk me through what the question is asking? I've been having difficulty with understanding what exactly is the glb and lub.
Hi Numnum! :smile:
Each hd is a function, and you can draw it on a 24-hour graph.
The minimum on that particular graph is Hd.
The greatest Hd (for all d in D) is H. :wink:
So for part a) I have to prove that for every h_d function, there exists a minimum? I'm not very good at proofs, so... What would I choose as the function?
Hi Numnum! :smile:
(just got up :zzz:)
I don't understand. :confused:
1) is asking you to prove a very standard result, viz., that a continuous function f on a finite closed interval [a,b] attains a maximum and a minimum.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
