Find Acceleration of Uniformly Accelerating Car | Kinematics Homework Help
  • Thread starter Thread starter Lucy_x
    Kinematics Urgent
A car accelerates uniformly and travels 18 meters during the fifth second of its motion, prompting a calculation of its acceleration. The initial confusion arises from interpreting "the fifth second" as the time interval between the fourth and fifth seconds, rather than the total time of motion. The correct approach involves using the equation d = ut + 0.5(at^2) while assuming an initial velocity of zero. Calculus may also be applied for a more precise solution by integrating acceleration to find the velocity function. Ultimately, the book's answer of 4.0 m/s² is confirmed through proper interpretation and calculation methods.
Lucy_x
A car that is accelerating uniformly travels 18 m in the fifth second of its motion.
Calculate acceleration.
I've tried to answer this a million different ways.
If it's in the fifth second on motion that means it has traveled for four seconds, yes?
And I'm not sure that this question gives enough variables for it to be answered... would you agree?
d=ut+0.5(at^2)
The answer in my book says 4.0 is correct. I can't seem to get this.
d=ut+0.5(at^2)
18=0+0.5(16a)
36=16a
36/16
=2.25
Then i was thinking perhaps it has traveled 18 m in 0.5 seconds only, so i did
:d=ut+0.5(at^2)
18=0=0.5(0.25a)
36=0.25
36/0.25
=144
Please help!
d=ut+0.5(at^2)
d=ut+0.5(at^2)
18=0+0.5(16a)
36=16a
36/16
=2.25
:d=ut+0.5(at^2)
18=0=0.5(0.25a)
36=0.25
36/0.25
=144
Please help!
Haha that's a trickyyyyyy problem. First off, You were right in that they failed to mention that the initial velocity is 0. I guess they want you to assume that although it's almost against all scientific principles to assume lol. Secondly, you'll have to use calculus. Think about integrating acceleration, letting it just be constant. Then, use your answer from there as the velocity function, v(t), and take a definite integral. Remember that a definite integral does not bring about another constant of integration. Finally, "in the fifth second" can be considered poor wording as most people wouldn't read it as "the interval between the 4th and 5th second," which is what it actually means. Hope that helps.
Thanks, just a few moments ago i realized that i can figure it out by calculating s1 and s2. Thanks for the answer, it helped a lot, though.
