Use of energy or force in spring question
The discussion centers on calculating the force constant of a bungee cord for a jumper who must stop 4m above a river. The initial calculation using Hooke's law was deemed incorrect because it did not account for the jumper's inertia after falling. It is emphasized that stopping a moving object requires more force than simply holding it up. The conversation highlights the importance of using energy considerations in dynamic scenarios, as static force calculations can lead to overshooting and potential danger. Ultimately, the choice between using force or energy depends on whether the situation involves static or dynamic conditions.
frostchaos123
Question is:
A balloon is 36m on top of a river, a bungee jumper has a unstretched cord of 25m attached to him and his weight is 700n
If he is to stop 4m above the river what should the force constant of the cord be?
My calculation is that since the cord can only extend 7m, using hooke's law I equate 700n = -k * 7 which gives 100. However I was told that the force method is not correct and I should consider energy at start and end points instead.
So my question why is the force reasoning incorrect and if there is a general way to tell how to choose, whether by force or by energy to solve a given problem?
That would be correct if the 700N man was statically loaded (i.e. wasn't dropped or falling). But since he is dropped from some height that person with the stiffness you calculated would overshoot and crash into the ground because he has inertia. It takes more force to stop something moving than to hold something up if that makes sense.
I see. In this case would it be correct to say that force should not be used, because even though the forces cancel out each other, there is a residual velocity that continues downwards and crash the person into the ground?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
