Use of forces to escape the Earth
Electromagnetism could theoretically be used to propel objects away from Earth, but practical applications face significant challenges. Achieving the necessary orbital velocity of over 17,000 MPH from the surface would likely result in atmospheric burn-up and create loud sonic booms. While concepts like rail guns have been explored, they are not feasible for Earth launches. Current propulsion systems already utilize electromagnetic forces, indicating ongoing research in this area. The discussion highlights the complexities of using electromagnetic propulsion to escape Earth's gravity.
rodgergibbs
If gravity is as we know a weak force and magnetism is a strong force, would it be possible to use electromagnetism to propel an object fast enough away from the Earth's surface to escape the pull of gravity and at least put an object in orbit. I assume you would need a long horizontal then curving into vertical trajectory. Has this ever been looked into?
Welcome to PF rodgergibbs. Theoretically you could use a rail gun to put an object into orbit from some solar system bodies. However, this isn't practical on earth. One big problem is the fact that orbital velocity is over 17,000 MPH which is well above mach one for a projectile being launched from the surface. Anything fired at that speed from the surface would likely burn up in the atmosphere. And, even if it didn't, it would create seriously loud sonic booms whenever it was launched.
Hello rodgergibbs, :welcome:
You still have to overcome gravity ...
And you bet it's been looked into ! Google electromagnetic railgun
We actually do that. All currently used propulsion systems are based on electromagnetic forces. Maybe you need to specify your question.
Likes BvU
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
