Using a Catalyst With Fuel Cells: Benefits and Challenges
Galvanic cells are designed to measure potential difference (V) without allowing the redox reaction to reach equilibrium, which would result in a power output of zero. In contrast, fuel cells continuously recycle reactants and products to maintain a high potential difference while generating power. The introduction of a catalyst in fuel cells aims to accelerate the reaction rate, which can enhance current (I) despite the potential risk of approaching equilibrium. The key challenge is balancing the need for a large potential difference, which requires the reaction to remain far from equilibrium, with the necessity of achieving a reasonable reaction speed to produce a decent current. This dual focus on maximizing both current and potential difference is essential for optimizing power output (P=VI) in fuel cells. The initial comparison to galvanic cells can be misleading, as the operational goals and dynamics differ significantly.
Big-Daddy
With galvanic cells, we assume that the redox reaction is kinetically inhibited so that equilibrium takes a long time to reach, so we can make a good measurement of the potential difference V. I thought fuel cells were the same originally, except that we recycle in reactants and products to make sure that there's enough of each to maintain a high potential V, so that we produce power (equal to IV where I is the current).
But now I came across the idea of using a catalyst with the fuel cell. That just doesn't make sense to me. The more the reaction occurs, the closer the system will get to equilibrium where V=0 and thus the power output is 0, so why would we want that? OK, so we are cycling in new reactants anyway, so the reaction will never be at equilibrium - but still, why would we want to catalyse it? What's the benefit in that, when the power output is based specifically on potential difference (which is a function of how much of the reaction is still left to go at any given moment in time)?
Chemistry news on Phys.org
No.
Apparently you still don't understand how the cell works and (hint) why do we have to close the circuit.
Borek said:
No.
Ok, so is it because we have two conflicting interests - keeping a large potential difference V for which we need the reaction nowhere near to equilibrium, and getting the reaction to go reasonably fast so that we can get a decent current, I, out of it - and we maximize power (P=VI) by trying to make the reaction go fast (maximize I) and pumping in new reactants constantly (maximize V)? Or am I still not understanding?
The confusion was caused because my book said this was "just like the galvanic cell" except that reactants are pumped in continuously. I think this was slightly misleading because there is a crucial difference - in galvanic cells, we don't want current to flow (even though it is inevitable that a little does) because we want to measure V without the redox reaction getting any (significantly) closer to equilibrium.
That's it.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
