Using Complex Impedances in these RLC Circuit Calculations
- Thread starter NaS4
- Start date
39 replies · 7K views · last reply
etotheipi
DaveE said:It can get scary. Look for the useful bits. If they get too abstract (math, philosophy and such) that may a good place to stop, or not, if you like that stuff.
Good place to start is Orodruin's article:
https://www.physicsforums.com/insights/learn-the-basics-of-dimensional-analysis/
Master1022
- 590
- 116
Just a quick update, I have checked my expression:
$$ Z = \left( \frac{\omega^4 R L^2 C^2}{(1-\omega^2 LC)^2 + (\omega CR)^2} \right) + j \left( \frac{\omega L (1 - \omega^2 LC + (\omega R C)^2)}{(1-\omega^2 LC)^2 + (\omega CR)^2} \right) $$
and think it is equal to yours (thus we are either both correct... or both wrong
Quick question about the problem statement: are the units of ## \omega ## a typo when it says Hz? Usually we expect ## \omega ## to be in rad/s (a conversion factor of ## 2 \pi ## is needed).
Am doing the calculations in a Python notebook, so will post pictures here to show how my calculations are resulting
NaS4
- 19
Yeah the w = 2(pi)f but since the question tells us that w is 200Master1022 said:Just a quick update, I have checked my expression:
and think it is equal to yours (thus we are either both correct... or both wrong!)
Master1022
- 590
- 116
NaS4 said:Yeah the w = 2(pi)f but since the question tells us that w is 200
Ah okay, that explains the discrepancy I had earlier. After setting ## \omega = 200 ##, I did get the same value of the gain and the final voltage as you (give or take some rounding errors) - the computer output ## 11551.24... ## (V), so this does agree with your result.
Hope that is of some help.
NaS4
- 19
Master1022 I got nothing but respect for you man. Really makes me happy to see people like you helping out people like meMaster1022 said:Ah okay, that explains the discrepancy I had earlier. After setting ## \omega = 200 ##, I did get the same value of the gain and the final voltage as you (give or take some rounding errors) - the computer output ## 11551.24... ## (V), so this does agree with your result.
2025 Award
- 4,608
- 4,341
It's very common for people to be sloppy about that. I guess they assume you'll know about the 2π correction.Master1022 said:Quick question about the problem statement: are the units of ω a typo when it says Hz? Usually we expect ω to be in rad/s (a conversion factor of 2π is needed).
Master1022
- 590
- 116
Happy to help, hopefully that answer is correct. One other sanity check is to see whether you can find a formula for the damping ratio of an RLC circuit with this setup and see whether it is very small (which is the only way such a large value of the gain is possible). I did have a quick glance on wikipedia, but I cannot see any similar variation. Regardless of the numerical values of the question, you did get the overall method correct (finding the transfer function and then calculating the gain).NaS4 said:Master1022 I got nothing but respect for you man. Really makes me happy to see people like you helping out people like me
I am going to ask @DaveE as I think he is more knowledgeable: can this topology of the RLC circuit be re-arranged into another form (eg. from the list on wiki here) such we can use the same formula for the damping ratio ## \zeta ##?
2025 Award
- 4,608
- 4,341
The canonical form for this particular LCR impedance is:
Z(s) = sL⋅(1+sRC)/(1+sRC+s2LC), where s=jω (sorry, I have habits that are hard to break!)
Then if you define some common features: ω=1/sqrt(LC), Zo=sqrt(L/C), Q=1/(2ζ)=Zo/R
The quadratic term looks like 1+(1/Q)(s/ω)+(s/ω)2.
This looks very different from the homework problem which wants a solution as a+ib. Hence a lot of algebra ensues.
The "factored pole-zero" or "ratio of factored polynominals" form above is how we really do this in EE/Controls world. I gives much better insight into the dynamics of this circuit. It's also easier to derive, IMO. Also notice that the polynomials are dimensionless, except the leading sL term, which is ohms, of course.
edit: all of my ω's above (except s=jω) should be ωo, it's not that ω, it's a constant.
Master1022
- 590
- 116
Thanks for the reply @DaveE !
$$ \zeta = \frac{R}{2} \sqrt \frac{C}{L} = \frac{10^4}{2} \sqrt{\frac{5 \cdot 10^{-6}}{20}} = 2.5 $$
which is odd because that doesn't suggest gain on the order of ## 10^3 ##...
Hmm, perhaps I ought to have another look over my algebra tomorrow to see if I come across any errors.
Thanks once again.
Agreed! (I also prefer working in the ##s##-domain)DaveE said:The canonical form for this particular LCR impedance is:
Yes, that is correct. This leads toDaveE said:Then if you define some common features: ω=1/sqrt(LC), Zo=sqrt(L/C), Q=1/(2ζ)=Zo/R
Thanks once again.
- lys04
- · Replies 26 ·
- Engineering and Comp Sci Homework Help
- Replies
- 26
- willow16v
- · Replies 1 ·
- Replies
- 1
- Color_of_Cyan
- · Replies 1 ·
- Replies
- 1
- e_brock123
- · Replies 1 ·
- Replies
- 1
- Maxamillion00
- · Replies 1 ·
- Calculus and Beyond Homework Help
- Replies
- 1
- fawk3s
- · Replies 5 ·
- Introductory Physics Homework Help
- Replies
- 5
- VictorWutang
- · Replies 5 ·
- Replies
- 5
- froldy
- · Replies 6 ·
- Replies
- 6
- nateja
- · Replies 2 ·
- Replies
- 2
