Using frequency to calculate resonances
  • Thread starter Thread starter jimisreincarn
    Frequency
In the experiment with a 4 m tube and a 256 Hz tuning fork, the calculation of resonances involves using the equation L = (1/4)(2n+1)λ. The speed of sound is given as 340 m/s, leading to a calculated wavelength of approximately 1.328125 m. Since one end of the tube is closed (with water at the other end), the correct approach is to evaluate the inequality 4 ≤ (2n+1)/4 * λ. This results in the conclusion that the maximum number of resonance structures is 5, as only integer values of n are permissible. The discussion emphasizes the importance of considering the tube's configuration and the impact of water level adjustments on resonance calculations.
jimisreincarn
1. If the length of the tube used in our experiment is 4 m, how many resonances would you observe when a tuning fork of frequency 256HZ is used?
2. v=f\lambda ; L = (1/4)(2n+1)\lambda
3. 340m/s = 256Hz\lambda \lambda = 1.328125m
4 = (1/4)(2n+1)(1.328125m)
12.05 = 2n+1
5.5 = n
We need to know what kind of tube you used in lab (open, one end closed, etc.)
one end of the tube is open. The other end has water at the end of it.
Ok and you probably raised the water level while ringing the tuning fork and marked where you heard resonances, right?
So this is a closed end tube. You are correct in using the equation L = \frac{2n+1}{4}\lambda
However, you are not correct in leaving L at 4 because you raised and lowered the water level. What you should do is evaluate the inequality 4 \leq \frac{2n+1}{4}\lambda
and solve for n. Of course you are only allowed integer values of n.
okay, that makes sense. so if my evaluation of the wavelength is correct, i would substitute it into the inequality and I should get n < 5? so at most there are 5 resonance structures.
Yep, that is what I get as well.
