Using Gauss (Divergence) theorem to find charge distribution on a conductor
The discussion revolves around applying Gauss's theorem and Gauss's law to demonstrate properties of charge distribution on conductors. The original poster seeks mathematical justifications for three specific statements regarding charge behavior on conductors and the electric field characteristics associated with them.
  • Participants discuss the need for mathematical reasoning to support qualitative justifications regarding charge distribution on conductors. There are inquiries about the application of Gauss's law and its implications for the stated properties.
Some participants have expressed uncertainty about how to mathematically approach the problem, while others encourage the original poster to engage with Gauss's law directly. There is an ongoing exploration of ideas without a clear consensus on the methods to be used.
Participants note that homework helpers typically require evidence of initial effort before providing assistance. There is an emphasis on understanding Gauss's law as a foundational concept for addressing the problem.
Alvine
Hi, I hope this is advanced enough to warrant being in this section:
I'm supposed to use the Gauss theorem (and presumably his law) to show:
1)The charge on a conductor is on the surface.
2)A closed hollow conductor shields its interior from fields due to charges outside, but doesn't shield its outside from fields due to charges placed inside it.
3)The field at the surface is normal to the surface and of magnitude (charge density)/epsilon0
I'm aware of the qualitative justifications but can't see how to do it this way. Can someone bail me out?
Thanks.
Hi and welcome to the forums Alvine.
What have you done with the problem? Do you have any thoughts/ideas on how to answer it? Homework helpers will not assist with any questions until you've shown your own effort on the problem.
Well I can do the last bit, but the other two I have no idea how to provide a mathematical reason for, all I can come up with is some hand-waving nonsense about equilibrium.
The question hints about Gauss's law. Do you know what Gauss's law is? If not, read it up and understand what it says. Then, make an attempt to apply it to this question. If you're stuck somewhere, post that bit here and people will be glad to assist.
  • · Replies 17 ·
