Using Gauss' theorem ande exploiting the cylindrical symmetry of the system, show
The discussion focuses on calculating the electric field at the point (L/2, L/100) due to a uniformly charged insulating wire using Gauss' theorem and cylindrical symmetry. The wire has a line charge density lambda and is positioned along the x-axis. The electric field E is derived as E = (100lambda)/(2pi epsilon0 L) by applying Gauss' law, where the area integral simplifies due to symmetry. Participants clarify the correct distance r to use in the calculations, confirming that r equals L/100, as it is the perpendicular distance from the wire to the point of interest. The discussion emphasizes the importance of correctly identifying the geometry in applying Gauss' theorem.
blueyellow
A wire of length L and negligible transverse dimensions, made of an insulating material, is placed on the x-axis between the origin and the point (L,0). The wire has a uniform line charge density lambda.
using Gauss' theorem and exploiting the cylindrical symmetry of the system, show that the electric field at the point (x,y)=(L/2,L/100) is
E=(100lambda)/(2pi epsilon0 L)
integral (S) E.da=E 2 pi r l
Q/(epsilon 0)=(lambda l)/(epsilon0)
2pi r l E=lambda l/epsilon0
E=(1/2 pi r l) (lambda l/epsilon0)
=lambda/(2 pi epsilon0 r)
but I don't know how to proceed from here
Plug in for the given value of r.
oh right! so r is just L/100 because it the wire is along the x axis, so I don't have to do L-L/2?
Right. The point where you want to evaluate the field is at a distance of L/100 from the wire, so that's the value of r you need to use.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
