Using power to find velocity (a car meets a hill)
A car weighing 6500 N with a velocity of 22.5 m/s on flat ground and an engine power of 78000 encounters an 8.1-degree incline. The discussion focuses on finding the new velocity on the hill while maintaining constant power and resistive forces. The initial approach involved calculating the force from the engine and adjusting for gravitational force using the equation P = Fv. The correct method requires recognizing that the total force on the hill is the sum of the engine force and the gravitational force, leading to the equation P = (F + Wsin(theta))V. Participants express urgency for clarification on the concept as homework is due soon, emphasizing the importance of understanding the physics for an upcoming test.
bopll
A car encounters an inclined plane
Given- Weight of car in N (6500), velocity on the flat surface (22.5 m/s), power of the engine (78000), incline of the hill (8.1 degrees)
Want to find- velocity on the hill (power and restistive forces remain constant)
P = Fvcos(theta)
I found F by plugging in the power and velocity. I then subtracted the gravitational force due to the hill from this number to get the resultant force. plugged this into P = Fvcos(theta) and got a number bigger than the original...
urgent help would be greatly appreciated since HW is due in 8 minutes, but I'm more worried about the concept for the test tomorrow. thanks.
The engine power is constant so the car is traveling at constant speed so that resistance is constant.
When going up hill - the car starts increasing its gravitational potential energy - and if the car's power output is constant, then the car's kinetic energy must be decreasing.
okay, so if i have to use kinetic energy, does that need i need to find the mass of the car (1/2mv^2)? that doesn't seem right...
edit: Ok I think I have it this time
Your flat ground situation is just P = FV. Move it around to get F = P/V. This is the force coming from the engine; it does not change. When you get on the hill, gravity applies a force against the motor as Wsin(theta). With this new net force, you find the new velocity.
Flat ground:
P = FV (start with this)
F = P/V (solve for force)
Hill:
P = (F + gravity)V
P is the same, F you find out, gravity is Wsin(theta), V is your answer. They are ADDED together because F and gravity represent DRAG as opposed to the force you are applying.
Flat ground:
Hill:
P = (F + gravity)V
i tried this also, maybe i made a calculation error...
