Can we apply the concept of net charge to subatomic particles?
  • Thread starter Thread starter ConfusedRookie
    Charge Term
The discussion centers on the application of the term "net charge" to subatomic particles like protons, neutrons, and electrons. Participants debate whether it is appropriate to use net charge calculations for these particles, with some arguing that it complicates understanding due to the unique structures of protons and electrons. Protons, composed of quarks, have a net charge of +1e, while neutrons have a net charge of 0. Electrons, being fundamental particles, are suggested to have a net charge of -1e without any uncharged components. The conversation highlights the complexities and differing opinions on the concept of net charge in the context of particle physics.
ConfusedRookie
Hello guy, I have questions with the use of the terms "net charge"
As far as I know we use net charge when we want to make a sum of positive charge + negative charge
For example the net charge of Na+ = +11+(-10)= +1
the net charge of Cl- = _______ = -1
But can we use the word net charges on subatomic particles such as protons and neutrons and also electrons !?
A proton has a net charge of 2/3e+ 2/3e- ⅓e= +1e (since it is made of quarks)
A neutron has a net charge of 0 (the same as a proton but the "sum" is zero)
An electron (it's not made up of any quarks according to the theory but I assume we can use say +0e - 1e = -1e.
You can indeed.
As far as I know you can. I don't think it makes a difference in the end since your final number is the same. 0e + (-1)e = -1e is the same as -1e.
What does the +0e stand for?
I disagree with @Drakkith, and think that you cannot do that. Why not say then that an electron is +5e -6e = -1e?
I suppose you could if you separated the unit of charge from the object possessing it, but that likely causes problems.
The main reason is that the proton is made up of quarks and the electron is not. (My opinion)
But what does your +0e stand for, with respect to the electron? An electron has no uncharged component.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
