Optimal Right Ascension Values for Star Viewing at Different Latitudes
  • Thread starter Thread starter Jimbob999
    Right ascension
For optimal star viewing on September 21st at a latitude of -32 degrees, the best right ascension values are between 7 hours and 17 hours, as the Sun will block the view from 0 to 6 hours and 18 to 24 hours. Conversely, at a latitude of 45 degrees, the ideal viewing times are from 0 to 5 hours and 19 to 24 hours due to similar solar obstruction. The discussion raises questions about how latitude affects these values and whether the inquiry fits the appropriate forum category. Participants seek clarification on the relationship between latitude and right ascension for precise star viewing. Overall, understanding these factors is crucial for effective stargazing at different locations.
Jimbob999
What range of values of right ascension would be best for viewing stars at a latitude of -32 degrees, 20 arcmins, 10 arcseconds on September 21st? What about an observer at 45deg22arcm11arcs?
N/A
On these dates the Sun would be approximately at 0 hours of right ascension in southern hemisphere as it is the vernal equinox. Because of this, between 0hrs and 6hrs of right ascension will be blocked by the sun as well as 18 to 24 hours. Thus between 7 hours of right ascension and 17 hours would be best for viewing the stars at this date. For northern hemisphere, 6-18hrs are blocked by the sun, therefore 0-5hr and 19-24hr are best for viewing.
I am not sure if I am on the right track here or not and how to get more precise based on the degree of latitude?
Hmm is this in the wrong subforum perhaps?
