How Do I Calculate Heat Flux for Water Flowing Through a Channel?
To calculate heat flux for water flowing through a channel, use steam tables to find the enthalpy difference, where the heat removed equals the change in enthalpy (dQ = dH). With known mass flow rate and heat flux, the vapor quality can be calculated using the formula Qin = Hout - Hin, rearranging to find Hout. The specific enthalpy (h) is multiplied by the mass flow rate to determine Hout. Once Hout is obtained, use the outlet pressure to find vapor quality (x) with the equation hout = hf + x hfg. This approach effectively combines thermodynamic principles and steam table data for accurate calculations.
banerjeerupak
Water is being used as a coolant by flowing through a channel. I know the mass flow rate of water. And i know the inlet properties of water. I also know that the water is coming out of the channel at a vapor quality of 1. How do i calculate the heat flux that the water is subjected to during flowing through the channel. I need the formula or the direction in which i can think to figure out the question.
Hi baner,
The easiest thing to do is just use steam tables. The heat removed is equal to the difference in enthalpy.
dQ = dH
Thank you Q,
That was helpful.
-Rupak
now there is a change in the calculations i need to perform. I have the heat flux and the mass flow rate. How should i go about calculating the vapor quality. I couldn't remember the formula, so thought of asking here.
You can use the same method.
Qin = Hout - Hin
so
Hout = Qin - Hin
Note: the above Qin and H have units of energy per unit time. H therefore, is the specific enthalpy (h) times mass flow rate.
Once you have hout (units are energy per unit mass) go to your steam tables. Given the pressure on the outlet, you can determine the quality by applying the following and solving for x :
hout = hf + x hfg
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
