What is the justification for the variation of the Lagrangian in an action?
The discussion focuses on deriving the variation of the action integral S = ∫ L(q, \dot{q}, t) dt and justifying the expression for δS. It involves considering the path of least action, x_l(t), and introducing a small perturbation, ζ(t), leading to a Taylor expansion of the Lagrangian. The variation δS is expressed in terms of the partial derivatives of L with respect to q and \dot{q}, capturing the first-order effects of the perturbation. The participants clarify the mathematical steps involved in this derivation, emphasizing the role of the chain rule in the process. The conversation concludes with appreciation for the explanation provided.
Identity
Given an action:
S = \int L(q,\dot{q},t) \,dt
The variation is:
\delta S = \int \left(\frac{\partial L}{\partial q}\delta q+\frac{\partial L}{\partial \dot{q}}\delta\dot{q}\right)\,dt
I'm guessing this is some type of chain rule, but I haven't been able to derive it... how is it justified?
Let x_{l}(t) be the path of least action. Consider the path x_{l}(t) + \zeta (t) where \zeta (t) << 1. So, S(x_{l}(t) + \zeta (t)) = \int_{t_{i}}^{t_{f}}L(x_{l}(t) + \zeta (t); \dot{x_{l}}(t) + \dot{\zeta }(t))dt After a taylor expansion to first order in \boldsymbol{\zeta }, S(x_{l}(t) + \zeta (t)) = \int_{t_{i}}^{t_{f}}[L(x_{l}(t), \dot{x_{l}}(t)) + \frac{\partial L}{\partial x(t)}\zeta (t) + \frac{\partial L}{\partial \dot{x}(t)}\dot{\zeta }(t)]dt (with the expansion terms along the path of least action) so the variation is given by \delta S = \int_{t_{i}}^{t_{f}}[ \frac{\partial L}{\partial x(t)}\zeta (t) + \frac{\partial L}{\partial \dot{x}(t)}\dot{\zeta }(t)]dt
Ah, thanks for that and the fast reply :)
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
