Vector Addition Using Components
The discussion revolves around solving a vector addition problem involving two forces of 40.0 N and 30.0 N at specified angles. The initial calculations incorrectly added the components, leading to a resultant force of 69 N instead of the correct answer of 15.6 N. The key correction involved recognizing that the y-components of the vectors are in opposite directions, necessitating subtraction rather than addition. After applying this adjustment and using the Pythagorean theorem correctly, the correct magnitude of the resultant vector was achieved. The importance of direction in vector addition was emphasized throughout the discussion.
Turquoise
Two forces are acting on a mass. One of the forces is a 40.0 N force and the other force is 30.0 N at the angles shown below:
The magnitude of the force is:
a) 15.3 N
b) 15.6 N <-- correct answer
c) 46.6 N
d) 69.0 N
Pythagorean Therom
Cosine, Sine
Vector
X component
A ax = (30.0N) Cos 20.0 = 28.2 N
B bx = (40.0 N)Cos 40.0 N = 30.6 N
Y component
ay = (30.0N)Sin 20.0 = 10.3 N
by = (40.0 N) Sin 40.0N = 25.7 N
C = ax+bx = 58.8 N Cy = 36 N
C = cx^2 + cy^2
C = 58.8N^2 + 36 N^2
C = 69 N
I keep getting 69 N and its not the correct answer. The correct answer is 15.6. I'm following the directions from my notes, but it gives me 69 every time. Help! What am I doing wrong?
Vectors have magnitude and direction.
Your ax and by are pulling in opposite directions, so are ay and by.
So subtraction, not addition, is the order of the day.
Then the magnitude of the resultant vector C will be the square root of the sum of the squares of the x and y components
Thanks! I got the correct answer now ;)
9K
11K
