Vector calculus identities and maxwell equations
Reloaded47
so we have the identity
\nabla\times\nabla\phi = 0
and from Maxwell's equations we have
\nabla\times \textbf{E} = -\frac{d\textbf{B}}{dt}
But we also have that
\textbf{E} = -\nabla\phi
So the problem I'm having is this
-\textbf{E} = \nabla\phi
which i substitute into the identity
\nabla\times -\textbf{E} = - ( \nabla\times\textbf{E} ) = 0
But this should be
\nabla\times - \textbf{E} = \frac{d\textbf{B}}{dt}
according to maxwell's equations, not zero
which is why I am getting confused
i think there is a good chance I've done somehing silly, i just need someone to point it out
Never mind i figured it out
\textbf{E} = - \nabla\phi - \frac{d\textbf{A}}{dt}
where
\textbf{B} = \nabla\times\textbf{A}
Yours is a good question. The fact is that you define a potential \phi if the field Eis conservative. But a field is conservative if its rotor is zero (irrotational).
This means that considering Maxwell's equation \nabla \cross \vec{E}=-\frac{\partial \vec{B}}{\partial t}, you can argue that IF -\frac{\partial \vec{B}}{\partial t}=0 then you can define \phi\backepsilon' \vec{E}=-\nabla\phi.
However, if you define \vec{B}=\nabla\cross\vec{A}, you could write \nabla \cross \vec{E}=-\frac{\partial \vec{B}}{\partial t}=-\frac{\partial}{\partial t}\nabla\cross\vec{A}\Rightarrow \nabla\cross\{\vec{E}+\frac{\partial\vec{A}}{\partial t}\}=0 so that the field \vec{E}+\frac{\partial\vec{A}}{\partial t} is irrotational, then conservative, so that \vec{E}+\frac{\partial\vec{A}}{\partial t}=-\nabla\phi\Rightarrow\vec{E}=-\nabla\phi-\frac{\partial\vec{A}}{\partial t}
This is a more general definition of the potential of the electric field that fits with Maxwell's equations. However, there is a term missing in my last expression related to a gauge transformation, but since it is a term related to the frame of reference, setting proper condition it can be put to zero.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
