Vector Calculus to derive Newton's second law
The discussion revolves around deriving Newton's second law using vector calculus, specifically for a particle moving in a circle with angular velocity ω. The user has identified the relationship between radius and velocity (r×ω=v) but is struggling with differentiating to find torque (τ=Iα). They applied the product rule and derived a=(v×ω)+(r×α), expressing confusion over the unfamiliar quantities involved. Additionally, there is a reminder about the importance of using a homework template to avoid potential deletion of the post. Clarification on the relationships between the vectors involved is sought to progress further.
pestydestroyer
THIS THREAD HAS BEEN MOVED FROM ANOTHER FORUM BECAUSE IT IS HOMEWORK. BUT THERE IS NO TEMPLATE.
Hi everyone,
The problem gives that a particle moves in a circle with angular velocity ω. I know that r×ω=v, which is the velocity of the particle. However, I am told to differentiate and find τ=Iα but, using the product rule, I found a=(v×ω)+(r×α). I am not sure where to go from here as these quantities don't seem familiar to me. Was there a step I missed or is there something I am missing in this step?
Thanks so much for any help.
Do you see any vectors that are parallel to one another?
Also this looks like a homework problem and so you should edit your post to use the homework template otherwise someone will delete it and warn you.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
