Vector Components Homework: Find Displacement for Bob to Return to Start Point
Bob's movement involves three segments: 200m south, 400m southwest, and 200m at 30 degrees east of north. The challenge is to calculate the displacement components for the 400m southwest segment, which is identified as vector B. The solution manual provides the components for the 200m segment as (100)i + (173)j and for the 400m southwest as -(283)i - (283)j. The discussion emphasizes the need for a visual representation, such as a sketch or scale drawing, to better understand the angles and distances involved in deriving these components. Understanding these vector components is crucial for determining the most direct route back to Bob's starting point.
ch2kb0x
Bob walks 200m south, walks 400m southwest, walks 200m in a direction 30 degrees east of north.
Use either trig or components to find displacement that will return bob to his starting point by the most direct route.
For this problem, I was able to find components for C, which is (200sin30)i + (200cos30)j,
but how do I find components for B. could somebody show me the steps to getting B components. I can do the rest.
B components?
Just picture this its very simple
200 south
.../ 400 southwest (assuming 45deg)
/then 30deg east of north, which i can't draw.
After explaining this I'm inclined to think that your question is what the angle measure is of 400m southwest, because they ask something else in the latter part of the question I'm inclined to think that they just want you to assume 45deg.
Sorry i didnt let you know what B was. B is the 400m southwest. In the solutions manual, they obtained (100) i + (173) j for the 200m in 30 degrees east of north which is equivalent to (200sin30)i + (200cos30)j. But they also had -(283)i - (283)j for 400m southwest. My question, is how is "-(283)i - (283)j" derived. It would be nice if someone could walk me through.
Did you draw a picture of B with all the distances and angles marked?
(If a sketch doesn't help, try a scale drawing, and you'll see what's going on.)
