Find Vector Components: A (17, 27°), B (26, 75°)
Vector A has a magnitude of 17 at an angle of 27° with the x-axis, while vector B has a magnitude of 26 at 75°. The discussion focuses on finding the resultant vector C for various operations involving A and B, including addition and subtraction. The user attempted to solve the problem by visualizing the vectors and calculating their components but received incorrect results from webassign. It is suggested to break down vectors A and B into their x and y components for accurate calculations.
susyq232
Vector A has a magnitude of 17 (in some unspecified units) and makes an angle of 27° with the x axis, and a vector B has a length of 26 and makes an angle of 75° with the x axis. Find the components of the vector in the following.
(a) C = A + B
(b) C = A - B
(c) C = A + 4B
(d) C= -A-7B
I did the entire problem and submitted it to webassign and it came back as wrong.
what i first did was draw vector a from the origin pointing up diagnally between the x and y axis. then from the tip of that i connected the tail of b pointing in also up diagnally between the x and y just with a sharper angle ( so the a is shaped like the bottwem half of the symbol '>' and then i added a '/' symbol to the tip)
so that's my picture. then i connected the end of A and the tip of B with a vector C. i then solved all the lengths of the smaller triangles then added ax and bx and ay and by to get the entire c vector's triangle for a+b = c. then i did ax-bx and ay-by to fnd a-b=c and so on.
my answers i got for the problem that webassign says is wrong:
(a) c= a + b
(39,56)
(b) c= a-b
(-7,-25)
(c) c= a + b4
(102,139)
(d) c= -a -7b
(-168,-237)
did you make any attempt at the problem? If you arent sure where to start, break the vectors A and B into their x and y components
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
