Vector evaluation & Lorentz force 02
The discussion centers on calculating the electromagnetic force on an electron in electric and magnetic fields using the Lorentz force law, F = q(E + v × B). The provided electric field E is 3.0 x 10^7 N/C and the magnetic field B is 3.0 T, with the electron's velocity given as v = 1.0 x 10^7 (2ex - ey). There is confusion regarding a typo in the example solution that mistakenly refers to the magnetic field value as the electric field. The final calculated force on the electron is 9.6 x 10^-12 N in the ey direction. This highlights the importance of accurately identifying vector components in electromagnetic calculations.
Roodles01
An electron in electric & magnetic fields;
E = 3.0x107 ex NC-1
B = 3.0 ez T
has velocity
v = 1.0x10^7 (2ex-ey)
Calculate em force on the electron.
I'm using the Lorentz force law here.
F = q(E + v X B)
I have an example solution using vectors to evaluate direction
| ex_______ey_______ez |
| 2.0x107_ 1.0x107 __ 0 |
| 0_______0________3.0 |
I think this has been posted as the solution to vXB,but then why is the E value 3.0 T there?
Could someone please ecplain why this is.
3.0 T is the B value, not the E value.
Oops, a typo, yes, but why is it there, how does it relate to the Lorentz law & is the solution
Final calculation 9.6x10-12 N
I seem to not be able to attach workings in a picture file, sorry.
The determinant will give you the cross product of v and B. The result of the determinant will be a vector. You then need to add the vector E to v x B and finally multiply by q.
OK
vXB = ex (3.0x107 - 0) + ey (-6.0x107 - 0) + ez (0)
q(vXB)= -e (3.0x107 ex + (-3.0x107 ex - 6.0x107 ey) + 6.0x107 * 1.6x10-19 ey) N
F = 9.6x10-12 ey N
