Vector Problem finding a certain endpoint.
  • Thread starter Thread starter charmedbeauty
    Vector
To find the midpoint of points A=(2,3,-1) and B=(4,-5,7), the calculation yields MA+B=(3,-1,3). The discussion highlights a misunderstanding regarding the relationship between the midpoints and the lengths of segments; specifically, the length of BQ is three times that of AB, leading to AQ being four times the length of AB. The correct approach involves using similar triangles to determine Q's coordinates, resulting in Q being calculated as Qx=10, among other coordinates. The conversation emphasizes the importance of accurately interpreting geometric relationships in vector problems.
charmedbeauty
Let A=(2,3,-1) and B=(4,-5,7). Find the midpoint of A and B. Find the point Q on the line through A and B such that B lies between A and Q and BQ is three times as long as AB
So to find the midpoint of A and B.
MA+B=(A+B)/2
RHS= (6,-2,6)/2
MA+B=(3,-1,3)
Next I said that the the midpoint of Q and A is 3 × (MA+B)
Hence MQ+A= (9,-3,9)
So now we have the midpoint and one endpoint of the line QA.
so Q+A=2(MQ+A)
so RHS= (18,-6,18)
Hence Q+2=18
Q+3=-6
Q-1=18
so Q=(16,-9,19)
But this was wrong I don't see why?
MA+B=(A+B)/2
Yes, that is correct.
RHS= (6,-2,6)/2
Why did you change from calling it "MA+B" to "RHS"?
MA+B=(3,-1,3)
Why would you think that? It certainly is NOT true. To take a simple case, suppose A= 0 and B= 1 on a number line. The distance from A to B is 1 and so the distance from B to Q must be 3. That is, Q= 1+ 3= 4. The midpoint of AB is 1/2 and the midpoint of AQ is 2. 2 is NOT 3 times 1/2.
so Q+A=2(MQ+A)
so RHS= (18,-6,18)
Hence Q+2=18
Q+3=-6
Q-1=18
so Q=(16,-9,19)
Because you entire logic is incorrect. The midpoint of AQ is NOT three times the midpoint of AB.
Instead, the length of BQ is three times the length of AB which means the length of AQ= AB+BQ is four times the length of AB. Using "similar triangles" that means that Qx= Ax+ 4(B[subx[/sub]- Ax)= 2+ 4(4- 2)= 2+ 4(2)= 10, etc.
Ohh yes it is for times the magnitude... so can I use the same method and say the midpoint of the new line is 4 times the original midpoint?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
