[VECTORS] Got the answer, lack visual understanding
  • Thread starter Thread starter aeromat
    Vectors Visual
The discussion centers on understanding the relationship between a line and a plane in three-dimensional space, specifically regarding parallelism. It confirms that a line is parallel to a plane if its direction vector is perpendicular to the plane's normal vector. A visual analogy is provided using the xy-plane, illustrating that a vector in the x-direction is perpendicular to the z-direction normal vector. The conversation emphasizes that any vector lying in the plane will also be perpendicular to the normal vector. This clarification aids in visualizing the geometric relationship between lines and planes.
aeromat
Which of the following lines is parallel to the plane 4x + y - z - 10 = 0?
ii)
x = -3t
y= -5 +2t
z = -10t
This is parallel, I confirmed it.
I already know that this line is parallel to the plane.
I know that if that "If this line is parallel to the plane then its direction vector must be perpendicular to the plane's normal vector". But I don't see how this is true visually. I drew it out and I still don't understand why that condition must be met
Are you asking for help visualizing the statement you have in quotations?
Think of something simple such as the xy-plane. Let's say you have a vector that's simply (1,0,0), so some unit vector pointing in the x-direction. Obviously it's parallel to the xy-plane right? Next you want to think about what the plane's normal vector is. Well, the xy-plane's normal vector must point in the z-direction. So your normal vector points in the z-direction (that is, a vector like (0,0,1) ), the parallel to the plane vector (1,0,0) points in the x-direction. So hopefully it's fairly obvious that those two vectors are perpendicular.
You can generalize it a little bit and say you don't need something in the x-direction alone. Any vector with no z-component will be perpendicular to that normal vector who only has a z-component.
I understand better now, thank you. And yes, the visualization was for the post-message in quotations.
Any vector that is in the plane is certainly perpendicular to the normal vector.
And any line that is parallel to the plane is parallel to a vector in the plane.
