Vectors in different planes add up to give a zero resultant?
Three or four vectors in different planes can indeed add up to give a zero resultant, provided they are arranged correctly in three-dimensional space. The discussion highlights that while vectors can be resolved into components along the i, j, and k axes, they must not all lie in the same defined plane to satisfy the problem's conditions. For example, two vectors can define a plane, and a third vector must not be in that same plane to achieve a zero resultant. The concept of a "crooked" plane is introduced, suggesting that vectors can still be in a single plane even if they don't align with the standard xy, xz, or yz planes. Overall, the arrangement and orientation of the vectors are crucial for achieving a zero resultant.
xphloem
Can
1. three
2. four
vectors in different planes add up to give a zero resultant?
1. Yes.
2. Yes.
1. suppose that we resolve the 3 vectors in i,j,k components. Putting each one of them zero in the respective three vectors to make them in 3 separate plane. Cant they be zero?
2. similar as above. the only thing is that the fourth vector has none of its components zero.
Am I right?
pl reply me
Hi xphloem,
For #1, were you thinking of something like this:
<br /> \begin{align}<br /> \vec A &amp;= (1,1,0)\nonumber\\<br /> \vec B &amp;= (-1,0,1)\nonumber\\<br /> \vec C &amp;= (0,-1,-1)\nonumber<br /> \end{align}<br />
They definitely add to zero, but they are in a single plane, so they don't satisfy the requirements of the problem.
For this problem: if you start with any two vectors, they define a plane. Then you want a third vector that is not in that same plane. Can those add to zero?
alphysicist said:
Hi xphloem,
How can all of them be in one plane
the first on is in xy plane
second one in xz plane
and the third in yz plane
am I wrong?
The three (essentially only 2) vectors A, B and C together form a 'new' plane, not like the xy, xz or yz plane, but you can also have a 'crooked' plane for example. Then they are still in the same plane, even though the plane is not the xy, yz or zx plane..
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
