Vectors Magnitudes and Angles (Respect to the X Axis)
The magnitude of vector V, calculated using the formula sqrt(Vx^2 + Vy^2), is confirmed to be 23.75 units. For the angle with respect to the x-axis, the initial calculation using tan^-1(Vy/Vx) yields 40.73 degrees, but this angle is in the fourth quadrant. To express the angle correctly as measured counterclockwise from the x-axis, it should be represented as -40.73 degrees, indicating it is below the horizontal axis. The discussion emphasizes the importance of understanding the reference direction when determining angles in vector analysis.
FAJISTE
a) If Vx = 18.00 units and Vy = -15.50 units, determine the magnitude of V.
b) Determine the angle of V with respect to the x-axis.
Yeah, Part B is pretty much the only one I don't get .
a) Answer is 23.75
b) I'm not too sure about what the whole "respect to the x-axis" means. The angle does lie in the fourth quadrant, so I assumed the answer is to do 360 degrees - the angle (i got 40.73) and get 319.27 but that didn't work. I'm down to one try for the answers, so I have to get this one right.
Thanks!
Magnitude = sqrt ( x^2 + y^2)
=> Magnitude = sqrt ( [(18).(18)] + [(-15.5)(-15.5)] )
=> Magnitude = sqrt (324 + 240.25)
=> Magnitude = sqrt ( 564.25)
=> Magnitude = 23.75
With part B I get the same answer as you using:
tan^-1 (y /x)
tan^-1 (15.5/18)
=> Angle = 40.73 degrees
Yeah, that answer is incorrect. I don't get what it means by respect to the x axis
If you want to measure it with respect to the x-axis it means that you start on the x - axis and move counter clockwise to your angle. I assume?
Ya, that gives me 360 - 40.73 = 319.27, which was wrong :(
Hmmm. What answer is given (assuming an answer is given)?
Wright the angle as -40.73 degree. Because angle in clockwise is taken as negative.
Are you sure? I have one last try and I don't want to get it wrong!
I think so.
im scared to try iot :(
can anyone confirm -40.73?
Yes, -40.73 is what I get too.
This means the angle is 40.73 degrees below the horizontal axis.
