Vectors Q: Solving OR & OP | Homework Forum
  • Thread starter Thread starter Eysz
    Vectors
The discussion revolves around solving a vector equation involving OR, OP, and PR. The user successfully derived an expression for OR but struggled with further simplification. They proposed substituting t=10 into the equation to express OR in terms of b, leading to a potential result of 4b. The response clarified that the direction of the vectors is crucial for the solution, emphasizing that OR must align with b. The user confirmed their understanding after this explanation.
Eysz
NOTE: Thread was moved to Homework forums and thus has no homework template...
I managed to find (a) but i couldn't figure out (b).
I think OR = OP + PR = (2/3)a + t( (-1/15)a + (2/5)b) but i don't know how to go further please guide or help me with this please. Thanks
There's a useful, directly observable, relationship between ##\vec{OR}## and b.
Then i should just substitute t=10 into the OR= (2/3)a + t( (-1/15)a + (2/5)b) since the answer must be in terms of b. That would make it 4b.
Is it correct?
Is it correct?
Yes, but not because you are told the answer must be in terms of b. You know from the diagram that it must be in the direction of b. Unless a and b are in the same direction, how else will you get (2/3)a + t( (-1/15)a + (2/5)b) to be a scalar multiple of b?
Likes Eysz
I completely understand now! Thanks!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
