Velocity of a falling object
It has to be 0.997 m, not 0.997 m^2In summary, we are tasked to determine the speed of a 0.163 kg ball, dropped from a height of 1.89 m, when it reaches a height of 0.997 m above the ground. Neglecting air resistance, the acceleration of gravity is 9.8 m/s^2. Using the equation Vf = sqrt(2aΔy), we can calculate the final velocity to be approximately 6.08 m/s. However, this equation is only valid when one type of energy is converted entirely into another, which is not the case in this problem. Instead, we should use the equation Vf
Physics-Pure
29
A ball of mass 0.163 kg is dropped from a
height 1.89 m above the ground.
The acceleration of gravity is 9.8 m/s^2
Neglecting air resistance, determine the
speed of the ball when it is at a height 0.997 m
above the ground.
Answer in units of m/s
Gravitational Energy = Kinetic Energy
Mass x Acceleration From Gravity x Height = 1/2 (mass)x(velocity)^2
Acceleration From Gravity x Height = 1/2 (velocity)^2 [mass cancels]
(9.8 m/s^2) x (1.89m) = 1/2 (velocity)^2
Velocity^2 = 2[(9.8 m/s^2) x (1.89m)]
Velocity = ~6.08 m/s
This is correct only when one kind of energy is converted entirely into another. Which is not the case in this problem. What equation should you really use?
Vf = sqrt 2a delta y?
above the ground.
Check the height.
I can confirm that your calculations and answer are correct. The velocity of the ball at a height of 0.997 m above the ground is approximately 6.08 m/s. This is due to the conservation of energy, where the gravitational potential energy at the initial height is converted into kinetic energy as the ball falls. Neglecting air resistance, the acceleration from gravity remains constant and can be used to calculate the velocity at any point during the fall. It is important to note that in real-world scenarios, air resistance would affect the velocity of the falling object.
1. What is the formula for calculating the velocity of a falling object?
The formula for calculating the velocity of a falling object is v = gt, where v is the velocity in meters per second (m/s), g is the acceleration due to gravity (9.8 m/s²), and t is the time in seconds.
2. Does the mass of the object affect its velocity when falling?
Yes, the mass of the object does affect its velocity when falling. According to Newton's Second Law of Motion, the force of gravity acting on an object is directly proportional to its mass. Therefore, a heavier object will experience a greater force of gravity and will accelerate faster, resulting in a higher velocity when falling.
3. How does air resistance impact the velocity of a falling object?
Air resistance, also known as drag, can have a significant impact on the velocity of a falling object. As an object falls, it moves through the air and experiences a force of resistance in the opposite direction of its motion. This force increases as the velocity of the object increases, eventually reaching a point where it equals the force of gravity. This is known as terminal velocity, and at this point, the object will no longer accelerate and will maintain a constant velocity.
4. Can an object have a negative velocity when falling?
Yes, an object can have a negative velocity when falling. This occurs when the object is moving in the opposite direction of the force of gravity, such as when it is thrown upwards. In this case, the velocity will be negative until the object reaches the highest point of its trajectory and begins to fall back towards the ground.
5. Does the height from which an object is dropped affect its velocity when falling?
The height from which an object is dropped does not affect its velocity when falling. According to the equation v = gt, the velocity of a falling object is only dependent on the acceleration due to gravity and the time it has been falling, not the initial height. However, the height may impact the time it takes for the object to reach the ground, and therefore the total distance traveled and the final velocity upon impact.
