What is the velocity of electrons when released from 1 nm apart?
  • Thread starter Thread starter accidentprone
    Electrons Velocity
When two electrons are released from a distance of 1 nm apart, they convert their initial electrical potential energy into kinetic energy as they move apart. The electric potential (V) between them decreases to zero as the distance (r) approaches infinity, leading to a final kinetic energy of zero if considered at that limit. However, the initial electrical energy is fully transformed into kinetic energy at a great distance. The discussion emphasizes applying the principle of energy conservation to find the velocity of the electrons. The conclusion is that the velocity can be calculated by equating initial electrical energy to final kinetic energy.
accidentprone
Two electrons are held 1 nm apart and then released. Assuming them to be classical particles, how fast will they be moving when they are far apart?
Not sure here really due to the lack of info give in the question. I know the work done would be qV and that this should be equal to the kinetic energy.
Also V = q / (4 (pi) (epsilon) (r)) where V is the electric potential caused by each electron and r is the distance between them.
If I let r go to infinity this means V tends to 0. Hence the kinetic energy is 0 and so is the velocity. This seems a little simplistic however! Can anyone confirm my reasoning?
Just a little accident in the last sentence!
The basic thing that is going on is that all the initial electrical energy is converted into kinetic energy when at a great distance (where, as you say, Ee is zero). So
Ee initial = Ek final
Put in your formulas and solve for v.
Thank you for the reply - I was so concerned about being told vaguely by the question that the electrons end up "far apart" that I completely ignored the 1 nm to begin with!
