Velocity of surface water wave
The discussion focuses on calculating the velocity of surface waves on water, likening it to the ripples created by a pebble thrown into a lake. The original poster references a formula for mechanical wave velocity, V = √((elastic property)/(inertial property)), but expresses confusion regarding its application to water, which is incompressible. A suggestion is made to refer to a specific physics resource that provides a derivation of the wave velocity for incompressible fluids. The conversation emphasizes the need to understand the nature of water waves, which are typically surface waves rather than longitudinal. Understanding these principles is essential for accurately determining wave velocity in water.
woepriest
Im trying to find the velocity for the surface wave on water. Its like when you throw a pebble on a small lake and there's waves.
My book tells me that all mechanical wave follows this
But water is not compressable and this wave is a longatuidal wave I believe. I am just stuck as to where to start.
Try here: http://physics.nmt.edu/~raymond/classes/ph13xbook/node7.html
The expression shown there can fairly easily be derived from the equations of motion for an incompressible, inviscid fluid.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
