Vertical Circular Motion of a giant wheel
The discussion centers on the physics of a giant wheel with a diameter of 40 meters, focusing on the forces acting on a man standing in a cage at the top of the wheel. When the wheel rotates, the normal force exerted by the platform equals the man's weight, leading to the equation T + mg = mv^2 / r. The tension is clarified as a normal force, and the forces in the normal direction are summed to derive N + W = mv^2 / r. The key to solving the problem lies in determining the normal force. The discussion emphasizes using Newton's laws to analyze the forces involved in vertical circular motion.
c.melissas
1. A giant wheel, 40 meters in diameter, is fitted with a cage and platform on which a man can stand. The wheel rotates at such a speed that when the cage is at the top of the wheel, then the force exerted by the man on the platform is equal to his weight. The speed of the man is:
2. T + mg = mv^2 / r and in this specific problem, v = m.
3. T + m(9.81) = mv^2 / 40
40(T + m(9.81)) = mv^2
Square root of [ (40(T + m(9.81))) / m ]
I think I am on the right track, but I am not really sure what do from this point.
Can you draw a free body diagram?
40m is the diameter.
First there is not a tension force really, it is more of a normal force since it is applied from the platform. That being said the key idea involves using Newtons law that forces are equal and opposite. If the platform feels a force of W by the man then what force is applied on the man by the platform? This is your normal force N. Then sum the forces in the normal direction to get N+W=mv^2/r. As mentioned above determine your normal force and the problem is solved.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
