Solving for Normal Force in Vertical Circular Motion Problem
In a vertical circular motion problem involving a pilot performing a loop, the normal force acting on the pilot at the bottom of the loop is calculated using the equation FN = m(v²/r) + mg. The pilot's weight (Fg) acts downward while the normal force (FN) acts upward, and their sum equals the net force (FR) required for circular motion. After substituting the given values, the normal force was determined to be 4112.18 N. The discussion emphasizes the importance of correctly applying the forces involved and clarifying the relationship between them. Understanding these dynamics is crucial for solving similar physics problems effectively.
Iser
A 76-kg pilot at an air show performs a loop de loop with his plane. At the bottom of the 52-m radius loop, the plane is moving at 48 m/s. Determine the normal force acting upon the pilot.
(ƩF)R = maR = m(v2/r)
I drew a diagram and I know I have to figure it out considering the position of the plane at the bottom of the plane. At the bottom of the plane FR and FN are pointing towards the center of the circle while Fg is pointing the opposite direction. Since the pilot has no movement in the y-direction we know:
FR + FN = Fg
After that I tried putting in the values I have but I got Fg's value was smaller than the total of FR + FN which does not make sense meaning I've made a mistake. I'm confused on how to tackle the problem after this part.
Iser said:
FR + FN = Fg
Only two forces act on the pilot: The upward normal force and the downward gravitational force. Their sum equals the net force, which in this case equals what you call FR.
Show what you got for FR, FN, and Fg.
FR is the resultant force, right? And I'm guessing you're taking FR, FN and Fg to be the absolute values. So the equation FR + FN = Fg is not quite right. Remember that the resultant force is not an extra force on its own. The resultant force is the force due to the sum of all other forces.
edit: whoops, Doc Al got there first.
Oh, ok I sort of see what you're getting at.
So by doing Fnet = FN - Fg
Then we use algebra to make it:
Fnet + Fg = FN
Which is then:
m(v2/r) + mg = FN
I then sub in the values I got from the question arriving to the answer of:
FN = 4112.18 N
Am I on the right track?
Fnet + Fg = FN
Which is then:
m(v2/r) + mg = FN
FN = 4112.18 N
Exactly right. :thumbs:
(Now compare that to what the normal force would be at the top of the loop. What's the key difference?)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
