Vertical Drop how to find the speed?
To determine the speed of riders before the braking system activates, the correct displacement of 21.1 m must be used instead of 21.6 m. The time of free fall can be calculated using the formula t = √(2d/g), resulting in approximately 2.08 seconds. The average speed is then calculated as speed = distance/time, yielding a speed of about 10.3 m/s. The discussion highlights the importance of using the correct displacement and understanding the relationship between acceleration and time. Accurate calculations are crucial for determining the speed in free fall scenarios.
ilovemynny
The Tower of Doom at Six Flags America lifts its riders to a height of 42.7 m, then releases them to free fall for 21.6m. How fast are the riders traveling before the magnetic induction braking system starts to slow them down?
t = \sqrt{}2d/g
t = (2)(21.6) / 9.81, square root
t = 4.40, square root
t = 2.10 s
21.6m / 2.10s
Speed = 10.3 m/s
I just wanted to see if I actually did this right and if I didn't can someone help me with it?
P.S. when i say ", square root" that means there's a square root in the equation
No that is not right. You calculated the average speed. If the riders drop with an acceleration of 9.8m/s^2 for a certain time t, what does that tell you about their acceleration at that time t?
their acceleration at 2.10s x 9.81m/s/s would equal to 20.6m/s/s/s
is it wrong because there are too many seconds?
No, the seconds in the time will cancel one of the seconds in the acceleration. Also, upon further inspection (ok, first inspection :redface: ), you are using the wrong distance. You need to use the actual displacement, 42.7m - 21.6m = 21.1m. Also, just to be a little nit-picky, to 3 significant figures, g = 9.80m/s^2.
oh, wow I thought the displacement would be 21.6 because that's how long the drop down was. Huh, okay so wait should I try the same formula again but with the 21.1m?
If I did use the same formula would it be:
(2)(21.1) / 9.80 square root
t = 2.08 s?
Bah, sorry! I misread the problem! Yes, you're right, 21.6. I thought it said they drop TO 21.6m
omg i actually did do something by myself right >.<
but wait wait is the formula still right to find time?
Yes, given an acceleration with no initial velocity and a displacement, d, that is how you find the time required to achieve that displacement.
so then time would equal to 2.1 s
and then
21.6m / 2.10s
Speed = 10.3 m/s
:biggrin: please tell me I'm right :rolleyes:
No no, you had it right at post #3 except for the minor g = 9.81 or g = 9.80 thing. The velocity is just Velocity = Acceleration * Time for a constant acceleration.
ohhh okay thank you so much! :!):biggrin::!):biggrin:
