What is the maximum speed of a 4.00kg mass attached to a spring with k=20.0N/m?
  • Thread starter Thread starter Gokuraku
The discussion revolves around calculating the maximum speed of a 4.00kg mass attached to a spring with a spring constant of 20.0 N/m, pulled 0.300m from equilibrium. The correct maximum speed is determined to be approximately 0.671 m/s, derived from the relationship between spring potential energy and kinetic energy. Initially, the poster miscalculated the speed as 0.612 m/s but later resolved the issue using the formula for spring energy and kinetic energy. The calculations confirmed that the total energy in the system is converted entirely into kinetic energy at maximum speed. The poster expressed gratitude for the assistance received during the problem-solving process.
Gokuraku
I'm sorry to bother anyone but this question is really driving me insane. It's one of my question on my notes and I've been trying to re-solve it.
It's in oscillatory unit and apparently we have to know what the speed is.
A 4.00kg mass is an horizontal frictionless surface attached to a spring with k=20.0N/m. The mass is pulled 0.300m from a equilibrium, then let go.
max speed
The answer is suppose to be 0.671m/s but I keep getting 0.612m/s...
..Never mind I figured it out.
Wspring=(1/2)kx^2
so W=.5*20*.3^2=.9
since the max speed is when all the energy is kinetic you can say the Wspring=(1/2)mv^2
so .9=.5*4*v^2
.45=v^2
sqrt(.45)=.6708 or .671
raindrops said:
Wspring=(1/2)kx^2
so W=.5*20*.3^2=.9
so .9=.5*4*v^2
.45=v^2
Thank you for replying, I'm very happy but I already solved it.
I just remember, when you told me, that kinetic energy is in there since it's in motion. Again, thank you and I'm very sorry.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
