lwymarie
- 90
- 1
What is thermal electricity?
What conditions (e.g. type of fuel) can make a flame pointed 'more upward'?
marlon said:I suppose the OP is referring to currents that are generated due to thermal excitation of the semi-conductor.
marlon
Thermal electricity is the conversion of heat energy into electrical energy. It is generated through the use of thermal power plants, which burn fuels such as coal, oil, or natural gas to produce heat. This heat is then used to boil water and create steam, which drives turbines that produce electricity.
The direction of the fuel flame is crucial in thermal electricity production. The flame needs to be directed towards the boiler walls to ensure efficient heat transfer and maximum combustion. If the flame is not directed properly, it can result in lower energy output and increased emissions.
The direction of a fuel flame is influenced by various factors such as the type of fuel being burned, the design of the boiler, and the air and fuel ratio. It is important to have a well-designed boiler and proper control of the air and fuel mixture to ensure the correct flame direction for optimal thermal electricity production.
Thermal electricity differs from other forms of electricity in the way it is generated. It relies on the combustion of fuels to produce heat, which is then converted into electricity. Other forms of electricity, such as solar or wind energy, use natural resources like sunlight or wind to directly generate electricity.
Thermal electricity production can have significant environmental impacts, primarily through the emission of greenhouse gases such as carbon dioxide and nitrogen oxides. These emissions contribute to air pollution and can also contribute to climate change. However, advancements in technology and the use of cleaner fuels have helped to reduce these impacts in recent years.
